Change indicator
08.05.2020 20:41 # 1
husem
Hello;
I want to get some information from our friends who know. When I change the indicator, does the old km appear or is it newly installed?
Let's say that the new one seems to be going back to the old one after wearing it. or will the newly installed indicator overwrite the old km?
I am asking them why am I going to search for a solution to cc problem by changing km. I want to not write my km in the indicators I will try, if there is a place held in my ECU in km information, I want it not to be written there.
I huseyın 2017-12-20 11:07:26
08.05.2020 20:41 # 2
Unfortunately my teacher writes the km on the indicator you have attached. Of course it is possible to have auto electronics, some of them are subject to km reduction.
08.05.2020 20:41 # 3
husem
So does my km pass my new one?
Will it go to the indicator that I will use as a donor that I wear 200 thousand km lower than me?
After all, I will put it back on the friend after I try.
I huseyın 2017-12-20 11:10:55
08.05.2020 20:41 # 4
Your km remains on your indicator, teacher. You will see whatever new indicator you wear is km. Your km will not go to the indicator you will use as a donor.
08.05.2020 20:41 # 5
husem
Thank you.
08.05.2020 20:41 # 6
Alicilik
Vehicle mileage theoretically
1 indicator brain
2 bsi remains registered in the brain.
When you wear a different bsi or indicator, whichever is highest, it varies in both brains.
So let's say that when your vehicle is at 150000km but the indicator you get is at 100000km, the indicator will record 150000km when you turn on the ignition and start the vehicle.
But if you put your indicator at 100000km and you put on the indicator at 150000km, this time the brain will detect 150000km and your vehicle will show 150000km.
If you are not sure of the km of the indicator, reset it in the brain cores before installing.
