central locking
17.08.2020 19:56 # 1
Ferhat38
My 2004 307 xs vehicle has a penultimate and central lock. But my problem is that I have to carry both the key and the remote. Most importantly, there was something called deadlock in these vehicles. He was closing the sunroof and windows that were open when the locking button was pressed for a long time. How can I run this Ferhat382020-08-17 19:57:49
18.08.2020 19:43 # 2
muzzy35
If mine turns off when you hold down the shutdown button, it is probably the same as you. The other problem is that if you go to the locksmith, you can combine the chip inside with the key in a different keychain.
18.08.2020 20:45 # 3
Ferhat38
No teacher, they wore the central lock brain than the one in the mfk brand hawks. Central lock not connected to the Bsi brain
18.08.2020 20:53 # 4
muzzy35
My friend, I think he knows the shortcut when he goes to the locksmith, maybe it was not active, open the ignition, press it 10 times or something, the room must be opened after the conversation, but there are not many cars that do not exist &# 129303;
18.08.2020 20:57 # 5
Ferhat38
Sir, I understand you too. There is already this feature in the car. But it is not connected to the brain of the central lock how do we translate it into the original. Does anyone know the connection
19.08.2020 08:11 # 6
When the original does not return, it will not work as you said. This job is solved in a good auto locksmith or electronics shop.
