Central lock shortage
08.05.2020 19:47 # 1
alfonsoxxx
Hello, when I bought the car, the remote control was working, it was not known to press too hard. The lock button started to not work. I had to open the key with the key for 2.3 months without using the control. When the lock key was pressed 5 times and changed by different electronics and key switch, the light of the control did not light up now, but it does not see the lock after pressing the ignition for 10 seconds. What would you say if I did: /
08.05.2020 19:47 # 2
the problem is the key is not in the spare key, I think my teacher has the best controlled new key, I think there is a problem in the current electronic circuit. worst case is your backup key.
08.05.2020 19:47 # 3
x571
[QUOTE = alfonsoxxx] Hello, the control was working when I bought the car. It is not known to press too hard. The lock button started to not work. I have opened it with the key for 2.3 months without using the remote control. I locked the car yesterday. The lock button was changed 4-5 times and changed by different electronics and key switch. When the lock button was pressed, the light of the control did not light up now, but it does not turn on the ignition and does not see the lock for 10 seconds. I do not think of brain tearing at all what do you say: / [/ QUOTE]
I had a key problem too. same conversations service :) did me too. the problem is in the key. have a new one and give it a try. I do not know how much the original service costs 500 TL in the industry. If there is a price that deviates from the hair, it never happened. You can get a new command from the 50 TL burglar alarms.
x571 2016-05-05 17:20:18
08.05.2020 19:47 # 4
[QUOTE = x571] [QUOTE = alfonsoxxx] Hello, the control was working when I bought the car. It is not known to press hard. the other said there was no room like that, the lock button was disassembled 4-5 times and changed by different electronics and key switch, when the lock button was pressed, the light of the control did not light up now, but it turns on the ignition and does not see the lock when pressed for 10 seconds. spoke to me, I do not think to have a brain disassembling for the central lock, what do you say? / [/ QUOTE]
auto key-makers are making between 100-200 TL.
08.05.2020 19:47 # 5
alfonsoxxx
I understood, thank you, I said I should make the replica of the keymaker Kople, 180 TL.
08.05.2020 19:47 # 6
Cyrus35
After the key has been removed by the lockers and removed and inserted, the key was introduced to the vehicle again and I recommend you to re-promote and try my one-key two-key.
