Central lock roland garros model
20.05.2020 16:04 # 1
Ankaragucu1910
The center has a lock, my car was running 2000 garros, it was not working, I said I would find the box and remove it and put it in the box, but there is no center in the box.
21.05.2020 02:50 # 2
rolandgarros
What is broken, my teacher, are you locking it again?
21.05.2020 12:58 # 3
Ankaragucu1910
I press the button on the key, it does not lock 10 days ago it was locked for 10 days, I locked the door with the key, it does not take it remotely. As I said, the center has the box of the lock, I find it, I find it, I want to remove the socket and reset it again, but it is not in the box.
21.05.2020 18:51 # 4
rolandgarros
maybe the remote's battery is exhausted
22.05.2020 07:56 # 5
Ankaragucu1910
I can change it or it can be the same
03.06.2020 02:11 # 6
Ankaragucu1910
It is not because of my battery change, I inserted the polarity and put it, so it resets it, maybe it is not because of it, does this figure have a socket box or fuse fuse somewhere?
04.06.2020 01:23 # 7
talip206
The mechanism is not something that will deteriorate easily. Either there is a problem with the battery of the remote or the control is broken. Pay attention to the battery code of the remote. I remember the code as 2016. After battery replacement, introduce the key to the car. If you write peugeot key definition in the forum and on the Internet, you will see how it's done.
04.06.2020 07:46 # 8
Ankaragucu1910
No masters, I found the remote recognition process from the booklet, but I did it, but no click better, maybe it works by itself.
