Central Lock Promotion
08.05.2020 15:41 # 1
cuneytatay
Hello to everyone
If the battery of the key in the key is exhausted or you cannot open the doors with the remote due to the contactlessness of the battery, you can introduce the key control in the central lock by following the steps below.
1. Open the driver's door using the key
2. Keep the door open
3. Insert the key into the contact
4. Press the black small button once
5. Turn the ignition to the start position.
6. Press and hold the large button for 10 seconds.
7. Release the button, turn off the ignition, remove the key.
8. Close the door (all doors must be closed)
9. Press the lock button 2 times.
10. If not according to this procedure, start and stop the vehicle. Do it again.
I tried it on my own vehicle worked. Sırıtma
08.05.2020 15:41 # 2
Haksen016
Thanks for the information.
08.05.2020 15:41 # 3
a useful sharing ....
08.05.2020 15:41 # 4
insomnia
harikasın
08.05.2020 15:41 # 5
iibrahimm
yaw friend what car are these?
08.05.2020 15:41 # 6
cuneytatay
how happy if i could be useful to me, thanks friends
08.05.2020 15:41 # 7
Erman41
I also think of changing the battery of the key, sometimes it hurts according to the head, sometimes it doesn't hurt at the same distance.
thanks in advance ..
08.05.2020 15:41 # 8
Platinium
Nice sharing thanks, there is no such situation in my car. I had removed the battery and it worked. :)
08.05.2020 15:41 # 9
cuneytatay
[QUOTE = Erman41] I also think of changing the battery of the key, sometimes it hurts according to the head, sometimes it doesn't hurt from the same distance. so that I will change :) He
Yeah, it was the same for me, then it didn't control when I changed the battery.
then I found this procedure from foreign forums.
I used the big button as the close button and the small button as the open button.
Good luck with Göz Kırpma
08.05.2020 15:41 # 10
[QUOTE = cuneytatay] [QUOTE = Erman41] I think of changing the battery of the key, sometimes it hurts according to the head, sometimes it doesn't hurt from the same distance. I do not do it wrong, I will change the battery :) He
There is one key in my car key. I use the same key to open or lock the doors. How can I introduce?
08.05.2020 15:41 # 11
Guys, if we copy a new key and bring the chip (for the remote control), can we introduce it this way?
I have one remote, one remote key, and if I take it from the button key and insert it with the button chip inside it, it is possible to introduce it in this way?
08.05.2020 15:41 # 12
yusuff
There's only one button, bro. there is no big or small button. How is it going to be?
08.05.2020 15:41 # 13
PeTeR_PaN
Hello to everyone
Friends, I have a 206cc vehicle, I went to an electrician recently with 2 keys. Angry He removed the fuse board under the steering wheel completely. I was bored alone, I noticed after I got out of there.
The doors of my vehicle are neither opened nor closed from the control. Now, I open the door of my vehicle with the key and start the car, I stop back, the control opens and closes. I come back to the car after 10 minutes, neither opening nor closing Cry It made me feel confused, nothing I did not do, but it does not improve. I am waiting for your suggestions ...
08.05.2020 15:41 # 14
sezar206
For those who have a single button, you hold the control next to the different vehicle. The red light is constantly lit and I do not remember if there is a need or something, but I was in the user manual.
08.05.2020 15:41 # 15
teoman_40
Friends, my car's original key is missing. There is no remote control in the spare key. I bought an external control system. They said the car does not support the system and they did not install it. Does anyone know about this? vehicle 2004 peugeot xr 1.4 hdi. There is a central locking system, I just bought a remote control system to trigger it from modacar, I do not need to connect the key that I will carry to the purpose of an external keychain. PRODUCT IS:
http://www.hepsiburada.com/Liste/modacar-m-cover- remote -acma-kapama-34b007 / productDetails.aspx? productId = otm34b007 & categoryId = 20029356 & SKU = OTM34B007 # Visuals
08.05.2020 15:41 # 16
furkanzul
My teacher said that the board is not working on the control of my vehicle. I will get a new key now, but it is very expensive in the service so there is a chip that does not have software in the new key I will bring from alieksprest.
08.05.2020 15:41 # 17
rg45
Friends in Kozyatağı Optimum about the Key
There is an Optimum Blue Switch. I had your card.
Sercan YILDIZ 05418008120
From this friend, we turned the key and alarm for 206 RG into a snap switch called a flip key.
He also installed the alarm on the keys on the key. For now, there is no problem.
Only the batteries will run out, 6 months or 1 year warns.
I am satisfied for now
I wanted to write if necessary.
08.05.2020 15:41 # 18
OguzhanKucuk61
[QUOTE = rg45] Friends in Kozyatağı Optimum regarding the Key
Is it possible to add a new alarm system to the existing key, without the need for additional key, sir? Did I get right ?
08.05.2020 15:41 # 19
rg45
[QUOTE = OguzhanKucuk61] [QUOTE = rg45] Friends in Kozyatağı Optimum regarding the key
Is it possible to add a new alarm system to the existing key, without the need for additional key, sir? Got it right? [/ QUOTE]
You got it right, hodja. It is so true that I was even surprised after its quality.
08.05.2020 15:41 # 20
OguzhanKucuk61
The key looks very stylish. Did you convert the original key into this system?
I asked the keymaker when I was making my original key switched, he said that we are introducing another system and converting it. In other words, it disrupts the original central locking system.
Take the original key inside and alarm
So, congratulations to you.
Page : / 2
