Central lock problem
08.05.2020 14:09 # 1
First of all, slmlar
Last week, I bought the 2006 model 206 x-design. The other day the vehicle had a central locking system malfunction. When I say lock from the remote, the locks are closed and reopened. strong> It says Right front door open . I researched in the forum, I just went and squeezed the 3m rust dissolver lubricant into the door lock. But it did not recover, did I get a cable or something? What should I do? I'm waiting for your help. Also, the forum is full of very useful information, thanks ...
h_307 2010-02-01 15:47:50
08.05.2020 14:09 # 2
hasimayaz
The central lock does not see the front right door closed, so you cannot lock it. the door trim needs to be removed and checked. If not, the door lock will change.
08.05.2020 14:09 # 3
Thanks, where do I open the upholstery, only 1 bolt seems?
08.05.2020 14:09 # 4
IF THE PARTNER LIKES NO BOLTS ALREADY PLASTIC CLIPS HAVE BEEN REMOVED FROM THE BOTTOM OF THE CIKIYO BUT ATTENTION TO REMOVE THE CUCHO BUT WHEN THE BIS BISO IS REMOVED.
08.05.2020 14:09 # 5
hasimayaz
http://www.peugeotturkey.com/nasil_yapilir.asp?MakaleID=13
