Central Lock Problem (307 XT 2004)
08.05.2020 20:30 # 1
SOP
Hello,
I have a 307 xt automatic 2004 model peugeot. My vehicle has been giving a strange problem for 4-5 days ...
When driving by car, the central lock locks itself, opening it immediately afterwards. Along the way, the doors are locked and unfolded (a constant tack lock sound inside!) ... And it does this one day, not another day.
Anyone faced with such a malfunction?
08.05.2020 20:30 # 2
maximusti
Makes this error when one of the doors or the trunk is not closed properly,
make sure it is completely closed,
if all of them are closed, the locking mechanism of one of them is broken or installed.
08.05.2020 20:31 # 3
Just like there is a problem with one of the door locks, I think you can take a WD40 and lubricate it beautifully.
08.05.2020 20:31 # 4
SOP
I showed it to a master, but he said the central lock brain took water. If so, I think it would give a fault warning on the screen. He couldn't solve the problem anyway ...
As you say, let's concentrate on the doors ...
Thanks
08.05.2020 20:31 # 5
As we said, it is hard to find a proper master.
08.05.2020 20:31 # 6
SOP
Exactly, we entrust the butchers with cars because they are masters.
08.05.2020 20:31 # 7
KILIC
As your friends say, there is probably a chassis on the door switches. Farewell control is broken. The masters are always starting with the most expensive solution
08.05.2020 20:31 # 8
ertuna
the opening handle of the trunk lid is electronic and a switch that can be damaged when it gets water may be from it, maybe it was also in me.
08.05.2020 20:31 # 9
SOP
[QUOTE = ertuna] The opening handle of the trunk lid is electronic and a switch that can be damaged when it gets water may be from it, maybe it was with me.
As if doing this problem more often for a few hours after using the trunk. You may be right;) I hope it is not an expensive piece that switch ...
08.05.2020 20:31 # 10
SOP
[QUOTE = SOP] [QUOTE = ertuna] the opening handle of the trunk lid is electronic and a switch that is likely to deteriorate when water is taken, it may have been the same for me. / quote]
Also, since this problem started, when I run the car in the morning, the "economy mode active" warning appears on the screen. Did you have such a thing?
08.05.2020 20:31 # 11
whisky
My teacher writes him because the battery is weak. Since we are in the summer, you can probably start in the morning, but in winter, when the weather gets cold, the car will not work. get a check of the battery, maybe it is he who disrupts the lock mechanism. as a result, when there is no battery, it is unlocked manually. as if it is weak, it affects your central system.
08.05.2020 20:31 # 12
ertuna
[QUOTE = SOP] [QUOTE = SOP] [QUOTE = ertuna] the opening handle of the tailgate was electronic and a switch that could be degraded when water was bought, maybe it was also from me. no water;) [/ QUOTE]
Also, since this problem started, when I run the car in the morning, the "economy mode active" warning appears on the screen. Did anything happen to you? [/ QUOTE]
Economy mode is active occasionally, it is not related to me.
08.05.2020 20:31 # 13
onlycihan
Let me tell you what I think, if the rear door switch is broken, the trunk lamp may be on all night and it may be weakening the battery. Even if the trunk is closed, the swich may remain open.
08.05.2020 20:31 # 14
maximusti
[QUOTE = SOP]
If one of the lock switches is short-circuited, it may be sucking the battery.
complete the lock mechanisms with the wd40.
