Central lock problem |
| 18.06.2020 21:39 | # 1 |
| 19.06.2020 08:48 | # 2 |
sonerkyl |
First of all, welcome to us. teacher, I checked the locksmith signal in the vehicle. does the key send a signal.
| 19.06.2020 09:22 | # 3 |
If you press the lock button of the lock button of the remote control for more than 3 times while the doors are open, the control will not work, you now turn the ignition key to the position, press the lock button of the remote control for 5 - 10 seconds, then release, lock the vehicle with the key switch on the console, then start the vehicle, then stop and go out and lock and lock the control check like
| 19.06.2020 09:51 | # 4 |
It does not receive a signal, we tried everything but it does not receive a signal. All locking system works normally except remote closing and opening.
| 19.06.2020 10:58 | # 5 |
sonerkyl |
Did you do what your friend said? I understand @ 307xr2005, by the way, use the products you bought goodbye. Try the following, to introduce the controller, sometimes this type of problems may occur when removing the battery. Synchronization of the remote control Turn off the ignition. Turn the ignition back on. Immediately press button A (door lock button) for a few seconds. Turn off the ignition and remove the key from the ignition. The remote control is functional again. "This is similar but a different expression .." After the control battery replacement, or when the control of the vehicle does not open or close the doors of the vehicle for any reason, it is necessary to introduce the remote control to the vehicle. This is called controller synchronization. To do this, insert our key into the keyhole on the driver's side and turn it in the locking direction. While keeping it rotated in the locking direction, we also hold down the control locking button. You will hear the door lock clicking sound when it is held pressed for about 5 seconds. Remove the key and press the door open button on the remote control. That is it, your key has been introduced to your vehicle again. Generally, this process is done to introduce the incoming key to the vehicle when a new key is ordered. Sometimes this action may be required when you change the controller battery. "
| 19.06.2020 11:00 | # 6 |
I did all the operations the problem is the same
| 19.06.2020 11:27 | # 7 |
no problem with switch buttons, right; The key may not have its original key. Make another key copy try it at once
| 19.06.2020 11:29 | # 8 |
I brought it to the original key shop, including the spare key, he said there is no problem with the keys.
| 19.06.2020 19:39 | # 9 |
My teacher, when it rained, it may have touched the brain between the windshield and the hood.
| 19.06.2020 20:39 | # 10 |
Well I looked, but I couldn't handle it because it would be worse, master by God.
| 19.06.2020 22:30 | # 11 |
It is very simple, in fact, you have blue plastic next to it, you pull it, at least if you do not fully remove yourself, pull that blue plastic, then snap it into place, you can do it by removing the battery while you do it, I did it myself, it is not necessary to use this tool.
| 19.06.2020 22:33 | # 12 |
You're telling the truth, they do it all too expensive
| 19.06.2020 22:38 | # 13 |
Also, if there is a water leak from the place I said, it spoils the cosmetics a little, but clean it well in a nice air and make silicone, or you will definitely buy the original and install it, isolate it.
| 19.06.2020 22:41 | # 14 |
There is a cover towards the glass, right next to the battery, you said, there are fuses under it and even
| 19.06.2020 22:48 | # 15 |
No, behind the battery, right behind the battery, the brain of the vehicle has a blue lock on the left side (it is in brnimk), you pull the socket, you pull it, do not force the socket
| 19.06.2020 22:50 | # 16 |
I can't even see my hand putting my hand behind the battery, I can't see the back of the battery at the very bottom. I think he stays with you
| 19.06.2020 22:52 | # 17 |
Summer from private president, I'll assign mine to you
| 19.06.2020 22:54 | # 18 |
I don't have permission, I can not enter the profile. Can you attack
| 19.06.2020 22:56 | # 19 |
I couldn't do it too, I said to you 128514; 128514;
| 19.06.2020 23:32 | # 20 |
Well I couldn't do it too, first name in the morning will be to check again,
