Central lock problem
08.05.2020 21:29 # 1
arifbsrn
Hello friends.
Since the original key control of the vehicle was faulty, I installed a new central locking system.
I found the lock motor's opening and closing wires from the driver's door. I connected it to the yellow and brown cables of the lock system. I connected the red-blue-yellow black wire and connected it to a free outlet in the fuse box. So far, no problem. When you press the control, the lock system reacts as clicks.
but the problem is that the doors don't lock.
the lock goes down by force, but it opens back immediately. (all doors are closed)
then, I lock the doors with the key, the control opens very hardly by pressing the unlock button. sometimes it can't.
In order for the lock system to be difficult, I removed the floor of the 4 doors and sprayed rust remover, and after a while, I sprayed a protective lubricant spray.
but nothing changed.
What is the problem, I could not get out of it.
I also noticed that the yellow and brown cables I connected to the door motor were getting hot.
I would be very glad if you can help with this interesting topic. thanks in advance.
