central lock computer
08.05.2020 20:01 # 1
hzr206
Hello friends, I have a central lock system in my car, but since the previous owner lost his key, he is not working right now. I want to wear a new brain, but I don't know how to connect the brain.
08.05.2020 20:01 # 2
monalos
: D I was traveling the central locks for 1 hour, they did not have the key like you, but those who installed the key to their existing central system.
If you have gone to the lockers or something, they can remove the original key from the system and copy the remote without installing the system again. I don't know what the prices are, but if it is expensive, then you will try to reconnect the system, you can follow the diagrams.
08.05.2020 20:01 # 3
iammanover
You don't need to have a new system. you need to get the key and code it to do the most robust service. iammanov is 2016-11-13 01:39:52
08.05.2020 20:01 # 4
hzr206
I did not go because the brain fees are around 50 lira, because the service fees are very high. Smile
08.05.2020 20:01 # 5
Eyup B.
check this topic.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=43161&title=sustali-206
08.05.2020 20:01 # 6
monalos
After fixing the door opening and closing ends, you can install central locks easily without problems.
08.05.2020 20:01 # 7
hzr206
I found the sockets on the doors, but I did not follow the cables, I would probably find the cable if it is going to the brain at the end. Thanks for the info
