Central Heating Started Working
08.05.2020 15:06 # 1
orhanetap
Hi
When he turned on the boiler, he started working loudly, as the grunt sounds like the propeller was touching somewhere, but I couldn't quite compare it to the propeller sound.
Less at level 1
It becomes more evident at level 2
It is not understood as the sound is already louder at levels 3 and 4.
There is no problem in heating, for now, or I could not understand.
Is there any advice? Is there anything I can do? Is my hand susceptible but no experience? Gülme
Or if I take it to a master, it is a costly thing, I would appreciate it if you could help.
Thanks in advance.
08.05.2020 15:06 # 2
d3Li
the same problem I have in my last wd40 I used to squeeze 1 2 days but then it started again
08.05.2020 15:06 # 3
phaselispa
I had the same recipe. The problem is probably something is stuck in the heating engine. For example, I have a cigarette gelatin.
08.05.2020 15:06 # 4
I think you can complete your shoulder.
08.05.2020 15:06 # 5
qEccE
friends, do you have a pollen filter in your vehicle? or did you ever look at the pollen filter? I had the same problem with me. I fixed the pollen filter and cleaned it.
08.05.2020 15:06 # 6
peugeotefe
It will be enough to replace the pollen filter of your vehicle, remove the heating engine and keep the air with the compressor.As the pollen filter pulls the dust out of the soil, the heating engine is covered with dust, just like the fans in the computer cases are covered with dust, so there is a problem in them.
peugeotef to 2011-02-19 12:27:35
08.05.2020 15:06 # 7
orhanetap
Thank you for your information, I will clean and try the pollen filter and engine
If it resolves, write msg again and I will inform you
08.05.2020 15:06 # 8
alpimis
Hello friends. I have the same problem and more. The heating engine works noisily at the 3rd and 4th levels and blows less despite running. In fact, he stopped for a while. At that time I was in Konya. The resistance has changed to 150 TL. The problem has been resolved, but it started to blow less then 10 days later and I think it will stop completely in the future. Service just changed parts. The burning that caused the problem did not do anything about melting or short circuit. At the first opportunity, I will try to apply what is described in the link below, but I do not understand electricity at all. http://www.peugeotcentral.co.uk/ftopic-717.html&postdays=0&postorder=asc&&start=100
Is there any friend who can help with pictures or diagrams? Respects.
08.05.2020 15:06 # 9
alpimis
My car 2004 307 1.4 hdi manually air conditioned.
08.05.2020 15:06 # 10
Muhammet CAKIR
[QUOTE = peugeotef A]
[/ QUOTE] Thumbs Up
08.05.2020 15:06 # 11
STALLONE
friends do not disassemble and clean, these works are okay, but for a short period of time, not only the room is cleaned, but the calorreria has beds, that is, the ball will change completely if they disassemble and replace it.
08.05.2020 15:06 # 12
If possible, can you describe how to dismantle the heating engine with pictures?
08.05.2020 15:06 # 13
boranaydogmus
I think the same problem starts with me. low level clutch sounds from there. I think the heater engine is out there somewhere. If you find illustrated narration, share it ...
08.05.2020 15:06 # 14
trtolgi
I would be glad if there is someone who can tell you how to disassemble the heating engine.
08.05.2020 15:06 # 15
We look forward to illustrated narration.
08.05.2020 15:06 # 16
orhanetap
How to do the cleaning process is already on the site :)
http://www.peugeotturkey.com/nasil_yapilir.asp?makaleıd=25
The voice still continues, but I'm waiting for the beginning of the month Confused compulsory oil came, I will remove all of them and I will share the result and what kind of a process is done.
