CENTER LOCK PROBLEM
08.05.2020 18:04 # 1
neon44
Greetings to all of you, my car 306 2001 model is now 15 days ago, when I locked it from the control and from the key, when there is no problem, when I try to lock it from the control, the door locks close and it hurts the same problem, when I try to lock it with the key, both of the doors are closed and it hurts with the key. It is locked after 5 or 6 times. Thank you God for the help of this problem or for the friends of the experience. Thank you.
08.05.2020 18:04 # 2
gebedek
Brother, you may be having this problem because any door (including baggage) is not locked, that is, it is not fully closed.
08.05.2020 18:04 # 3
neon44
bro, thank you for bothering and replying, but even though I don't check all the doors or even in the trunk, some of them say swich but I couldn't find out where you are.
08.05.2020 18:04 # 4
sezar206
the vehicle is detecting one of the locks open maybe
08.05.2020 18:04 # 5
kuscu38
[QUOTE = pregnant] Sister, you may be having this problem because any door (including baggage) is not locked, that is, it is not closed properly.
Exactly, teacher, I had a problem when I checked one by one, the door closes ...
08.05.2020 18:04 # 6
Turgay_66
My advice to you is to try unscrewing the doors one by one, find out which door is wrong and then start the process :) Turgay_66 2013-11-15 23:29:00
08.05.2020 18:04 # 7
neon44
I wonder if the hinges you call door plugs are there
08.05.2020 18:04 # 8
ahmed206
Yes, I think he meant it, is the interior lamp still on when the doors are closed? a good examination probably understandable
08.05.2020 18:04 # 9
Turgay_66
[QUOTE = neon44] I wonder if the hinges you call door plugs are there
[/ QUOTE] yes, teacher, take them out one by one, close the doors and lock them from the remote control, which door has a problem :)
08.05.2020 18:04 # 10
Bunyamin.Kar
One of the locks is jamming and the same has happened to me, the locks that open and close normally until now are not locked now as if you were joking, it opens as you close, take the contact spray, one of the door locks will be solved with a nice spray, the problem will be solved from the leanness.
08.05.2020 18:04 # 11
neon44
Thank you bro, I will try and I will go crazy
08.05.2020 18:04 # 12
fth306
I have a similar problem: (the key is not entering from the driver's side, I go in from the side and close it with my hand and hold my hand, then I try to exit without moving the other door, I lock it with the key. I leave the doors open only when I lock the trunk: D Of course, if the car is going to stay in safe places for a long time, I try to do it.
08.05.2020 18:04 # 13
Bunyamin.Kar
The door is not locked, it is not like the sockets, at least it was not what happened to me, if the lock is locked in the door or if it touches a place, you are the audience, the system reopens, when I remove the door trim, it came to my head, I lock the door, it opens as I lock it, it finally unlocks the complete lock, I examined it, I said it is the dirt in the door lock, I put the thinner in the glass bottle and squeezed it and cleaned it, the problem was solved.It took a week like this, it started again, I unscrewed the lock again at the weekend. The lock mechanism I cleaned with thinner did not lock the mechanism because it was not rubbed because of the friction mechanism. I removed the top parts of the lock as far as I could, I was able to feed the 10/40 remaining from the engine oil of the vehicle with a picture brush, a nice 1.5-2 months passed, no problem.
08.05.2020 18:04 # 14
abdullahaydn52
I had the same problem. English right front door was not showing on the screen. I had the electrician cancel the sensor of the door and the problem went away. it was even better. other locks do not open when the right front door is opened. Something good for someone with small children like me.
