ceiling lighting
08.05.2020 16:47 # 1
falan
friends, this led bulb is on my ceiling & nbsp; warning?
08.05.2020 16:47 # 2
osman.goksel
warning
08.05.2020 16:47 # 3
falan
thank you
08.05.2020 16:47 # 4
falan
Well, would it be sufficient lighting? would you recommend
08.05.2020 16:47 # 5
Ozgur
The lighting of the 206s is not enough. I know who wears it.
08.05.2020 16:47 # 6
savi_206
I use the same for ceiling and trunk lighting. Much better than yellow light. I advise
08.05.2020 16:47 # 7
falan
can we put the same in the trunk?
08.05.2020 16:47 # 8
ufuk91
Oh, it is very nice. If it fits our ceiling and trunk, I will buy it, but the price seems a little salty.
08.05.2020 16:47 # 9
ufuk91
or would philips be better instead?
http://www.hepsiburada.com/List/philips-photon-magnum -5-LED-white-bottomless-park-bulb-841 388 / productdetails.aspx? ProductID = otm841388 & amp; # Comments CategoryID = 20,024,643
08.05.2020 16:47 # 10
herry
Very bad lighting led, like a day .. herry 2012-05-19 18:40:50
08.05.2020 16:47 # 11
GO--GO
i have philips like the car daytime
08.05.2020 16:47 # 12
MuratUlg
So let me ask something else :) Would it be a problem if I use these bottomless bulbs instead of the bulbs on the information screen?
08.05.2020 16:47 # 13
[QUOTE = MuratUlg] then let me ask something else :) Would it be a problem if I use these bottomless bulbs instead of the bulbs on the information screen? [/ QUOTE]
unfortunately you need to find a smaller led bulb or led strip like me (cheaper)
08.05.2020 16:47 # 14
ufuk91
friends, I have a question how many volts are our parking bulbs in the original? I will make the parks in the headlights green, and I found the following: 24 volts, is it confused, are these 206ya?
http://urun.gittigidiyor.com/garaj/xk-carub-ampul-24-volt-far-ici- lED-green-br0400-57366527
08.05.2020 16:47 # 15
ufuk91
so as far as I know it should be 12 volts in ours
08.05.2020 16:47 # 16
falan
friends, my bidet mine ashtray lamp is not on. I changed the bulbs but it was not burned again .. any idea?
08.05.2020 16:47 # 17
falan
08.05.2020 16:47 # 18
[QUOTE = or something] or friends, my bidet mine ashtray lamp is not on. I changed the bulbs but it was not burned again .. any idea? [/ QUOTE]
Are you burning the headlights, not "Star"
08.05.2020 16:47 # 19
Cmoss06
Our vehicles need 12 volts plus the right connection of led diode bulbs + anode - cathode tips.
08.05.2020 16:47 # 20
Cmoss06
It is in 24-volt bulbs, but you need to remove the bulb from the plastic socket and change the resistance in it. Ideal resistance for 12 volts 390R ohms I always use 12 V 390R.
Page : / 2
