Ceiling Lamps Do Not Work ..
08.05.2020 18:08 # 1
dreamcast87
Hello Friends,
& nbsp;
As I can see in my signature, I disassembled the roof lamp of my 307 vehicle and accidentally short-circuited when measuring how many volts are coming, then right and right on my ceiling lamp. My left lamps have become inoperable, they have fused, but I did not know which fuse to replace, so I wanted to consult you. There is no problem with the middle lamp, it works when the door is opened and closed and opened by myself, but the lamps on the right and left sides do not work when the car is running or not working. I took a picture of the fuses located where the left BSI is, I hope the problem is solved :(
Thank you in advance. < / strong>
& nbsp;
& nbsp;
& nbsp;
08.05.2020 18:08 # 2
Serkan
My 5 amp fuse number F7, but Front and rear roof lamps, map reading lamps, glove box lighting seem to be the only fuse, so the problem may not be from the fuse.
08.05.2020 18:08 # 3
dreamcast87
Well, where do you think this might be caused by? So it was working before accidentally short-circuiting then it stopped working. If you say from a single fuse, is it possible that the lamps may have exploded? If I remove the right and left lamps and put them in the middle lamp, it burns, if the problem doesn't burn from anything else like you said, I burst the bulbs.
08.05.2020 18:08 # 4
Serkan
Try the light bulbs and fuse as a single fuse in the instruction manual. If it is neither of them, it may be a little difficult to solve, as the system may have been damaged.
08.05.2020 18:08 # 5
dreamcast87
Thank you very much for your interest. I tried the first bulbs, not breaking, it is working normally. I last changed the insurance. It started to burn in the left and right lamps :) What I do not understand is that if this fuse failed, how did the middle lamp turn on the taillight and the torpedo, it did not burn the right left lamps, and all of them got better after installing a really interesting new fuse. This issue is at least for the friends who have the same problem :)
08.05.2020 18:08 # 6
Serkan
Well, sir, I couldn't make much sense in me, but it was resolved after all :)
