Ceiling lamp and Follow Me (Help)
08.05.2020 17:47 # 1
Aziz
I have a problem with friends, I wanted to practice the Talip (tlp), but the situation is wrong with me.
I have a box in the picture below.
the following is written on the box what is my current saver :)))
LDB-H
252
09 01
PTI
clear image for jack and diode
this is the detail and condition of the ceiling lamp (I had to extend it to remove all the cables and work comfortably)
I take a single line from red, it works yes but reverse AngryAngryAngryAngry
When the doors are locked, the ceiling lamp goes out, the parks are burning, when it is opened, the ceiling lamp lights up, the parks turn off. OuchCryConfused
08.05.2020 17:47 # 2
umut_25
I think the friend who is the inventor of this work, Talip, is very close to you. I think if you take 1 Liter of coke and go, it will not reject the request for help :)
08.05.2020 17:47 # 3
Aziz
He still said to him in the suitor: D
08.05.2020 17:47 # 4
tlp
My dear friend :)
The little box behind the headlights is on all LED headlights
There are resistors in that box, overcurrent is prevented by resistance
Each led headlights have these circuits (headlight, stop, strobe).
If you detected the central lock cable in the ceiling light, you misconnected the cable in the headlights
You will need to find the main line of the parks, sockets / boxes are a system related to your headlights, because the headlight has a DLR led system.
That black and white and white cables are the cables of the DLR system.
The actual cable you need to connect should be farther back and probably surrounded by a black coating.
I may not explain it here, but your connection point in the headlights is absolutely wrong
You can do something like this to try
Take the cable you pulled into the fender signals and connect it to the + (plus) end of the fender signal and try again
By the way, do not forget that the gray part of the diode will be facing the parks tLp 2013-07-11 15:59:06
08.05.2020 17:47 # 5
moschino
I am not trying to do it right now
ceiling lamp lit when opening the doors
it quadruples
hour
not working :(
08.05.2020 17:47 # 6
tlp
[QUOTE = tanerfiliz] I swear I didn't try to do it right now
it quadruples
hour
not working :(
Fell out of insurance
It works if you remove the blown fuse in the fuse box and install another fuse of the same value
08.05.2020 17:47 # 7
tlp
You marked "this jack" in a saint picture
I don't know who put on the headlight
I guess jack came next to the headlights
They tied the jack to the cable of the parks for convenience.
and as far as I can see, the cables of the jack go under the headlight
Parking cables in the vehicle's own system may be under the headlight
08.05.2020 17:47 # 8
moschino
We looked at your insurance, but all the fuses are intact.
We looked at the peugeot private service and we went to the auto electrician, we could not find any waste insurance.
they are connected to the computer, it seems to be working on the button but there is no physical reaction
They said, let's take a look at the installation completely, I don't know where I did wrong
08.05.2020 17:47 # 9
Aziz
[QUOTE = tlp] My dear friend :)
By the way, do not forget that the gray part of the diode will be facing the parks [/ QUOTE]
Let me try the wave, I will give it to the first parking entrance of the vehicle, not from the headlight's own led system. D: I'll be back in 15 minutes :)
08.05.2020 17:47 # 10
tlp
Exactly
08.05.2020 17:47 # 11
tlp
We looked at [QUOTE = tanerfiliz] insurance, but all fuses are intact.
Ceiling lamp, quadruples etc. It works by triggering the central lock.
Is there a window lifting module in your vehicle?
I don't think there will be a complete plumbing situation
Not in a computerized situation
Certainly the work of the central lock brain
While doing, he usually throws insurance due to sas
Whatever wisdom I did at once
We tried Honda, the system of honda did not fit
He also fused insurance, we renewed
08.05.2020 17:47 # 12
moschino
Yes, there is a central lock and the windows close automatically when I lock the doors. (windshields only)
08.05.2020 17:47 # 13
tlp
Look at the glass lifting module then
Maybe he can do it
08.05.2020 17:47 # 14
BerkeKarayel
saint brother has thrown out of the fuse says right suitor brother, you will get the original headlight socket of the car +12 parking attachment, take the cable in two parts to bi12volt potential. Of course, the parks must be open. When the portable light bulb is on, take an attachment from the cable of the pin you are trying ... :)
08.05.2020 17:47 # 15
Alicilik
Remove the battery head while doing the operations, gentlemen. Check the chassis and contacts and reconnect them after finished 12v man will not crash but can ruin the car
receptivity 2013-07-11 23:28:51
08.05.2020 17:47 # 16
Aziz
[QUOTE = Receivability] Remove the battery head while performing operations, gentlemen. Check the chassis and contacts and reconnect them after finished 12v man will not crash but can ruin the car
You're late my receiver for this warning: ((
No, no editor should delete this topic.
08.05.2020 17:47 # 17
moschino
it quadruples
hour
not working :(
I'm frustrated too like you
