CD reading problem
08.05.2020 19:51 # 1
ymehmet
Friends are good forums.
The cd player of my car mostly does not read cds. Would you recommend me to buy a new cd player or do I have the original repaired?
08.05.2020 19:51 # 2
getting it repaired will cost you but its life is reduced. If you buy a new tape, you should definitely choose the one that is compatible with the remote control.
08.05.2020 19:51 # 3
xmen
Which CDs do not read, Hojam, original CDs or CDs that you have written yourself.
08.05.2020 19:51 # 4
sanctuary35
burn cd with fewer songs at slower speed
08.05.2020 19:51 # 5
OguzhanKucuk61
MP3 doesn't play anyway. You have to write it as a track. If you don't track, it won't play. If it does not play even though there is a track, there is a problem in the CD eye. My orig. At that moment in tape
08.05.2020 19:51 # 6
Barut
These tapes do not read every writing CD. Cd should be of good quality, it was the smoothest running I was using philips, write at slow speed. Follow what I said and it works flawlessly if the tape is not faulty. I also recommend pioneer as a tape, you activate and use the joystick.
08.05.2020 19:51 # 7
themurat54
There are optical cleaning CDs for computers, there is a small brush on the CD. I don't know if it will work in the car, but I think it's worth trying.
08.05.2020 19:51 # 8
ymehmet
I write CDs in low-speed tracks, but still don't. He forcibly read the original CD in 7-8 attempts. But as I said, I was undecided, if I had the original repaired or if I had a Pioneer or another remote-compatible zero tape as my gunpowder said ;?
08.05.2020 19:51 # 9
TRK
[QUOTE = Gunpowder] These tapes don't read every writing CD. Cd should be of good quality, it was the smoothest running I was using philips, write at slow speed. Follow what I said and it works flawlessly if the tape is not faulty. I also recommend pioneer as a tape, you activate and use the joystick. [/ QUOTE]
Hi Gunpowder,
Which tape would you recommend, and how do we handle the joystick activation event?
08.05.2020 19:51 # 10
Barut
[QUOTE = TRK] [QUOTE = Gunpowder] These tapes do not read every writing CD. Cd should be of good quality, it was the smoothest running I was using philips, write at slow speed. Follow what I said and it works flawlessly if the tape is not faulty. I also recommend pioneer as a tape, you activate and use the joystick. [/ QUOTE]
Hi Gunpowder,
I recommend the Pioneer deh-x2750ui, it has two amps and forward-looking, I use it in my own car, which is very reasonable in price. There is a friend in Izmir, 50 TL for the remote control event. I can give a number.
08.05.2020 19:51 # 11
Barut
If you want to get cheaper, you can look at the lower series of the pioner, non-cd versions are cheaper around 170.
08.05.2020 19:51 # 12
ARDADOGAN
no hassle, put a new tape on it, but be careful to have w / r input on the back of the tape, make sure it has aux like it. but keep the original tape works to set the time date Do not disassemble the original socket in one
08.05.2020 19:51 # 13
ymehmet
Thanks Arda my teacher is already running the original tape only track. You can burn CDs and listen to 17-18 songs for the music you want.
08.05.2020 19:51 # 14
TRK
[QUOTE = Gunpowder] [QUOTE = TRK] [QUOTE = Gunpowder] These tapes don't read every writing CD. Cd should be of good quality, it was the smoothest running I was using philips, write at slow speed. Follow what I said and it works flawlessly if the tape is not faulty. I also recommend pioneer as a tape, you activate and use the joystick. [/ QUOTE]
Hi Gunpowder,
I recommend the Pioneer deh-x2750ui, it has two amps and forward-looking, I use it in my own car, which is very reasonable in price. There is a friend in Izmir, 50 TL for the remote control event. I can give a number. [/ QUOTE]
OK I will concentrate on the model you call Gunpowder. This weekend I will handle it somehow. If you want to send your phone, you can call your friend's phone in Izmir here or privately. I will contact him.
