Cd reading problem
08.05.2020 15:43 # 1
tilbe307
He takes 307 CDs, tries to read and then goes to the radio. He says no cd. why do you think
08.05.2020 15:43 # 2
Check if the cd you are using is scratched. Make sure the
cd is an audio audio cd.
Open the
and clean the eye with alcohol cotton swab. There is a 50% solution.
08.05.2020 15:43 # 3
tilbe307
thank you first how can i open it for reply so well inside
08.05.2020 15:43 # 4
It is easy to open the inside of the tape. If you have removed the
st you will see the cd unit when you open the two screws on the cover. then open the screw on its 4 sides. Disconnect the tape from the tape. Collect cologne on the napkin and gently wipe 2-3 times. don't put too much pressure on the eyes.
08.05.2020 15:43 # 5
tilbe307
I did not remove the tape before, nor the CD. Do I do any damage?
08.05.2020 15:43 # 6
Do not attempt this job if you do not have mechanical and electronic knowledge of my teacher. & nbsp; There are alcoholic CDs to clean cd roms in electronic markets. suitable for the end user. Like listening to music, you put the CD on tape and it is cleaned when the CD comes out.
