Cd player problem
08.05.2020 14:15 # 1
t@lip
Hello friends,
I have an RD4 Cd player in my car, I don't know if it was caused by the weather getting hot but it gets stuck occasionally while removing the CD. The tip of the CD is visible, it does not eject completely. No problem playing or importing the CD. When the CD is inserted, inserting the credit card on the CD and squeezing it passes the CD and it comes out. Has anyone faced and dealt with this problem? If it is a problem that myself cannot handle, where can I have it repaired in Ankara, what is the estimated cost? Thank you very much for your sharing, wishes without accident, driving without accident ..
08.05.2020 14:15 # 2
t@lip
I guess nobody knows, thank you ..
08.05.2020 14:15 # 3
H-a-d-i
If the CD does not return, the problem is in the gears. If you can, you can also change it. you can benefit from a blessing like konya street. but I think it is necessary to review at least 50 TL. Of course, it seems like it ends up to 10 TL if you do it yourself.
08.05.2020 14:15 # 4
okan77
"You can benefit from a blessing like konya street." I couldn't understand this part ...
Sorry can you help my friend ...
08.05.2020 14:15 # 5
H-a-d-i
There is a neighborhood in Ankara where electronic materials are sold. It is famous. I think it's within the borders of the Nation.
08.05.2020 14:15 # 6
okan77
There is also a Karaköy selanik passage in Istanbul and places selling electronic equipment on its opposite street.
I wonder if the parts that will change can be found here
08.05.2020 14:15 # 7
H-a-d-i
I think it can be found. it can be found by going to that passage by first opening the device, detecting and removing the parts that need to be replaced.
08.05.2020 14:15 # 8
t@lip
Come on, sir, I had opened an RD4 unit before and examined its interior. To open the device, the bottom cover needs to be removed, i.e. the top cover is integrated into the right, left and back covers. In order to reach the mechanism that takes the CD out after the bottom cover is removed, the plate that is just above the bottom cover must be removed and its cables must be removed. So it is almost impossible to watch while the mechanism is working. I don't think I can handle it when I think about it.
In this case, a few questions come to mind immediately.
>> What can be done to find the malfunctioning gear in the unit as I described?
>> Can Konya street RD4 repair the unit, if it replaces it, replaces the entire mechanical unit instead of a single gear in the mechanical unit. Because it all takes at least 100TL as I guess.
Come on, Okan Beyler, thank you for your interest.
t @ lip 2010-05-12 13:11:07
08.05.2020 14:15 # 9
H-a-d-i
I did not see the inside of the device. When I said you can do it yourself, I meant those who are skilful. As you said, if the mechanical complete changes, 100 TL will be comfortable. maybe more. but only gear is 40-50. Also, I don't know if there are mechanics there. everybody knows, it's electronics paradise.
08.05.2020 14:15 # 10
okan77
If the problem is with the gears, it is already crumbled into a wear or dust player.
we need to see the plastic parts. In this case, the problem is replaced by a worn gear counterpart.
resolvable. As a result, the mechanical part is broken, the cd plays with aging and unworkable track replacement.
it can be repaired ... If there is an electronic part, then it will also exceed me
