CD player
08.05.2020 16:54 # 1
secur73
friends peugeot 307 xt 2003 model's cassette player is converted into cd player ?? where can i find it ?? i have any problems ?? thanks
08.05.2020 16:54 # 2
Sure. If you mean the ones in the original 307s when you say cd calar, you have to find one of the exits. This way it won't work if you install it in your vehicle. It is necessary to connect your vehicle with the computer and write the vehicle's chassis number on the radio. You can get this done anywhere in PP2000.
08.05.2020 16:54 # 3
secur73
Tşkkürler ...
08.05.2020 16:54 # 4
Let's be careful about this issue, you should make sure that the cd players you will get out of are giving cd reading errors. Also, these cd players called rd3 are expensive.
08.05.2020 16:54 # 5
ByHack
Instead of the cassette player you mean, I know that the cd players with the CD player feature (in the makeup case) do not match the connection cables in the old cases. This is unlikely if you have any obsessions such as cd .alar and controlling the radio from the steering console. these can be connected to the Blaupunkt tape deck. It can also be controlled from the steering wheel control. In these cd players alone, I am overhauling the problem for almost 2 months. Either it compresses the cd, or as soon as you take it out, if everything works properly, it will not read the cd :) believe it. I am currently thinking about double religion style things. I've never had a 7 "navigation device in there and I'm going to make my own double religion :)
