CD player
08.05.2020 15:16 # 1
ozi033
You know, most of the cd players in the 307s are defective. When I bought the car, the cd player was removed. They mounted it at the bottom. If I think the cd player is up.cd player is canceled now. My question is whether the tape recorder attached later can be adjusted with the steering wheel control .. Can we have this done by an electrician outside.
08.05.2020 15:16 # 2
When you say cd calar, are you talking about cd changer or cd ca on tape? I had to ask this because the cd player is already on the top cd changer at the bottom. It can be repaired according to the problem, of course, but it depends on what the problem is.
For your 2nd question, when you say the tape that is followed later, is it the original tape or another brand of tape like pioneer? If it is original, you can use the steering control. If it is not original, it can be used with some apparatus. I think you can leave normal electronic electronics and you can do it easily. Of course, electronics makes it more comfortable.
08.05.2020 15:16 # 3
ozi033
yes, I meant cd changer when I say cd player. I thought the original 5 cd changer was on the top. I also thought that they changed their places when they were at the bottom right now .. I am using the cd player tape that I am currently using. Can I make this tape, which I am using now, compatible with the steering wheel.
08.05.2020 15:16 # 4
[QUOTE = ozi033] yes I wanted to say cd changer when I say cd player.I thought the original 5 cd changer was on the top. Of those stuck ... so now can I make this tape that I use now, compatible with the steering wheel .. [/ QUOTE]
Yes it does. You can control it from the steering arm with an apparatus called XCarlink. Follow the title:
http://forum.peugeotturkey.com/forum_posts.asp?tıd=9701&title=xcarlink-duyan-varm
08.05.2020 15:16 # 5
ozi033
Thank you..but the price was too much .. not ..
08.05.2020 15:16 # 6
[QUOTE = ozi033] thank you..but the price was too high .. we did not .. we extend our hand and turn the sound off. Thanks anyway.))) [/ QUOTE]
Well everything is not cheap Göz Kırpma
