Cd Changer
08.05.2020 15:07 # 1
Ako06
Hello friends .. My car 2002 model 307 xt. blaupunk brand cd has 5 cd changer. My problem is that the car reads the original CDs, but it does not read the CDs I have taken. thanks.
08.05.2020 15:07 # 2
You need to burn the CDs in Audio CD format. You can print from Windows Media Player. Alternatively, you can use Nero's Burn Music CD section. berkayg is 2011-02-26 21:56:14
08.05.2020 15:07 # 3
naksi
if not, the cd chncer eye is dusty clean reads every audio cd
08.05.2020 15:07 # 4
metin
it is a little fragile, sometimes it doesn't even read the originals.
If you try to burn the cd in track format and at slow speed then it will most likely open.
In the meantime, for the newcomers to the forum, you should introduce yourself to our members.
08.05.2020 15:07 # 5
Ako06
I throw the songs as tracks, I print them at the lowest speed but I don't read again, I couldn't handle it.
08.05.2020 15:07 # 6
Ako06
Yav is not giving back the CDs now. lights are blinking. help me friends :(
08.05.2020 15:07 # 7
They are chronic problems. :)
Press and hold the button for 10-15 seconds, whichever slot the CD does not turn off the tape.
08.05.2020 15:07 # 8
sercinho
Brother, these are not working for me. I have to look at you, but if there are not many kind of tools, I will give you an address.
08.05.2020 15:07 # 9
How to solve a similar problem in this link is explained step by step.
http://www.peugeotforums.com/forums/showthread.php?t=13240
08.05.2020 15:07 # 10
Ako06
I can't understand that site because I don't know much English. We'll handle it somehow. But what can I do about playing cd? . I took the CD as a track, I shoot it at the slowest speed again. How can I clean the lenses?
08.05.2020 15:07 # 11
sercinho
I think it is a bit of a problem.
08.05.2020 15:07 # 12
Ako06
Is there a place you know, Brother?
08.05.2020 15:07 # 13
sercinho
mesut electronics 4.cad no: 37 / a labor / ankara tel 2299977
Brother, I want to call this place, I bought this place from the lake when I was in the service, if there is anything in the service, do not you go there.
08.05.2020 15:07 # 14
Ako06
okay sagola brother
08.05.2020 15:07 # 15
Ako06
[QUOTE = berkaygr] Chronic problems. :)
I applied what he called a master. I did it with the tape off, I did not.
08.05.2020 15:07 # 16
teknikerrr
I think show it to a good tape master without ever touching cd changer.
These tools are very delicate. If you break the lens adjustment or something, you can collect more difficult.
It was mine, it was mechanically locked, I tried a little bit, but it is not easy to interfere with that device. I did not dare even though I was engaged in electronic work.
08.05.2020 15:07 # 17
mimitt
It makes you realize the CDs you use, DMS prof series is using CDs, my uncle throws an average of 17 18 songs at low speed every time in 307, sometimes there are 20 problems, but I do not read the princo at home :)
08.05.2020 15:07 # 18
MaximuS
friends, never mind this chancer job ... after a while does not hold stitches. and all that cost goes to waste. I did not rebuild it in the 3rd fault and I got into the x car link event. I recommend it to all of you. a very useful and quality device ...
