CC is not engaged
08.05.2020 18:27 # 1
SDYMZ
I have been using it for about a year without any problems.
08.05.2020 18:27 # 2
Alicilik
Have there been any errors or changes in brain configurations?
08.05.2020 18:27 # 3
ByHack
Hodja, I had the same problem, and I even mentioned the subject I just opened. I suggest you consider the possibility of the brake sensor. When the brake end of the brake sensor slips back, it can not perform its full function and cause this error. for your information...
08.05.2020 18:27 # 4
SDYMZ
[QUOTE = Retrieval] Have any errors or changes in brain configurations?
[/ QUOTE] Once the diesel hose had been punctured, a related engine malfunction lamp had turned on. I replaced the hose and the lamp went out. a lot of CC was working from this event
08.05.2020 18:27 # 5
Alicilik
Bsi and ecu should there be a mistake, it should be a mutevellit problem.
08.05.2020 18:27 # 6
Serkan
I experienced the brake sensor problem both in 206 and C3, check the handle, the tip may have escaped, it may be out of order
08.05.2020 18:27 # 7
Alicilik
If the brake light is broken, it seems that the brake light does not light up, but when it is on the double side, I can not say for sure it can be on the clutch. It may even cause another error in the brain. The service hurt the joke in a 207 and it was not closed when it closed.
08.05.2020 18:27 # 8
SDYMZ
The problem was solved when I changed it due to brake sensor. I checked the drainage sensor with the measuring instrument, he has no problem
08.05.2020 18:27 # 9
ByHack
i said Big smile
08.05.2020 18:27 # 10
SDYMZ
[QUOTE = ByHack] I said Big smile [/ QUOTE]
Thank you, I already looked at the brake sensor after you said
