Causes Rust Upside Down
08.05.2020 16:26 # 1
denizcAn
There is wetness in the back right side as if it was spilled under the rust rust as if it was 5.LT water. What Is The Reason For This?
08.05.2020 16:26 # 2
___KxL___
There may be leakage from the heater core or the pipes coming into the comb. you should check.
08.05.2020 16:26 # 3
Alicilik
The same happens when I turn it on. They said normal, but not normal.
08.05.2020 16:26 # 4
___KxL___
Is it normal? over time, it will rot at the safe.
08.05.2020 16:26 # 5
denizcAn
It Had Been Once More Before. Now I Never Understand It Has Been Gone 1 Year Vehicle.
08.05.2020 16:26 # 6
denizcAn
It especially happens in rainy weather.
08.05.2020 16:26 # 7
Back right side says yahu heater what is there? & Nbsp; "Ermm"
Generally, it is caused by gas pump There will be wetness due to leaks, but I think yours gets rainwater from inside. Can't you get anything out of the warranty?
08.05.2020 16:26 # 8
denizcAn
I have to deal, but I don't have free time :) I'll take a time when I'm available.
08.05.2020 16:26 # 9
brutal
If it is from the right side, it is the point of the two things in the rain .. the right fender hood breaks or breaks or the sheet metal part under the passenger seat is deformed due to any reason and the tire pops on the tire while the vehicle is traveling. There is a grill if it is broken the water will be filled.
08.05.2020 16:26 # 10
denizcAn
Right Front Fume Hood Broken Teacher. I guess I don't think so.
08.05.2020 16:26 # 11
denizcAn
There are a lot of leaves full of windshield grills. Could there be from it? But I wasn't able to figure out what relevance was under the right rear pass.
08.05.2020 16:26 # 12
brutal
The carpet draws the water and distributes the teacher, because the place is much cheaper than the other places.
08.05.2020 16:26 # 13
denizcAn
I hope it is like you said, There is no other problem.
08.05.2020 16:26 # 14
qqyyxx
It is probably due to door wicks. If there is water accumulation on the carpet or wetness, the probability of coming from below is zero. As far as I know & nbsp; it is integrated with a nylon-style coating.
08.05.2020 16:26 # 15
SAVAS
The hole that drains rainwater under the door is clogged. the same happened to my albea before. I asked one of the taxi driver, the man instantly resolved the event. & nbsp; There is a need to clean the clogs from time to time with something fine-tipped. undrained rainwater leaks from the door lining to the floor. & nbsp;
08.05.2020 16:26 # 16
ismail ozdemir
Just as the right Taşhis door tires do not have water left and the door leaks from under the door due to tear over time.
08.05.2020 16:26 # 17
Bavik
You go to an electrician, look at the calcareous radiator reputation, I had the same problem, my right mat was wet, but the caliper radiator has changed.
08.05.2020 16:26 # 18
comolokko
I took the door wicks in my self. Corsa was filled with water in the trunk of the corridor. We did not find it replaced. I sat down one day, I removed whatever it was because of the half tire curl of the stop tire. It was cut when it was fixed.
08.05.2020 16:26 # 19
fTh206
[QUOTE = denizcAn] There is Wet as if 5.LT Water Spilled Under the Rust on the Rear Right Side. What Is The Reason For This?
