Causes of Poor Mixture
08.05.2020 13:59 # 1
1- The float needle is stuck in the carburetor due to the waxing of the gasoline, it is cleaned.
2- The float is set too low, the setting is renewed.
3- Carburetor inlet strainer is clogged and cleaned.
4- Fuel pump is defective or its capacity is insufficient, it is checked.
5- The filter of the fuel pump is clogged, it is cleaned or replaced with a new one.
6- Fuel pump filter cover gasket is defective and replaced.
7- Flexible fuel pipes, if any, are twisted, broken or tightened.
8- Between the pump and the tank, fuel pipes are bent, blocked, or drilled.
9- The air hole in the fuel filler cap is clogged or narrowed and cleaned.
(SHARED FOR YOU FROM MY COURSE NOTE)
08.05.2020 13:59 # 2
sinan-s
Thanks for sharing
08.05.2020 13:59 # 3
Ismail
thanks for sharing
08.05.2020 13:59 # 4
Melih brother, we have a subaru impreza gt on the car while the car is on the road after turning on the turbo, the car can smash the land and make it again. By the way, have a good holiday
08.05.2020 13:59 # 5
sinan-s
[QUOTE = STI HUNTER]
It would be nice if you introduced yourself.
