cause of failure? 206 van
08.05.2020 16:05 # 1
bugsbuni
good evening my brothers ..
I am a 206 user, the car has been in 140 thousand for the last 1 week, after the third gear, is it from turbo or valve? No sound comes anymore, when I press full throttle, the sound is cut off. What could be the reason?
08.05.2020 16:05 # 2
What Kind of Sound Whistling Is Like ???
Great Chance Injectors Shoot.
I would say Turbo, but when you press the gas you say it cuts ...
If You Have The Possibility To Record The Sound We Can Help You Clearly, Maybe, Göz Kırpma
08.05.2020 16:05 # 3
bugsbuni
Well, brother, I can record the sound if I have the opportunity, but a voice sounds like "shrrrrr".
What would be the expense of injectors?
08.05.2020 16:05 # 4
In my opinion, it can be made from injectors ... Because it is often the injector makes the sound you call shrrr. Depending on the rate of pressing the gas, spraying is cutting from the variable ...
If injectors change, I guess it will be costly. I do not have full information about the price, but I guess the new one can be 500 TL ... The friends who know will help more clearly ...
08.05.2020 16:05 # 5
bugsbuni
exactly, my brother, when I press the cut exactly according to the rate of pressing the gas, the sound is cut off completely.
08.05.2020 16:05 # 6
berk2309
There is a possibility of piercing the python if it sprays too much. There was an imbalance in our pejo boxer.
