Catalytic converter fault and Antipollution fault |
| 08.05.2020 14:10 | # 1 |
| 08.05.2020 14:10 | # 2 |
Onur |
Since it is a gasoline vehicle, it may be difficult to say that the gasoline is dirty, if the catalyst is installed or if there is a rich and poor mixture, how many kilometers does the vehicle give this error? |
| 08.05.2020 14:10 | # 3 |
93,000 km. It has been 2 months since I received maintenance at 90,000. I bought the car, I buy gas from the same gasoline Petrol Ofisi
| 08.05.2020 14:10 | # 4 |
okan77 |
I recommend shell ...
| 08.05.2020 14:10 | # 5 |
There is PO and opet on my way, I am getting from PO. But if you recommend, I'll continue with the shell.
| 08.05.2020 14:10 | # 6 |
Onur |
shell or opet
| 08.05.2020 14:10 | # 7 |
I think if I change the fuel problem, my fuel problem will be okay?
| 08.05.2020 14:10 | # 8 |
it is good to replace the fuel and try again .. if not, cancel the catalytic.
| 08.05.2020 14:10 | # 9 |
Vehicles with a catalytic converter work only with unleaded gasoline to the best of my knowledge. If you bought it normally or super, it may not be repaired and one-to-one replacement may be required. you will either change it or cancel it. both increase in performance :))
| 08.05.2020 14:10 | # 10 |
I buy 95 octane gasoline, now I have half a tank of gasoline, should I wait for it to decrease or should I buy gasoline immediately?
| 08.05.2020 14:10 | # 11 |
finish the tank completely
| 08.05.2020 14:10 | # 12 |
In my car the other day, Catalytic converter fault error appeared suddenly , my car trembled and stopped. The reason for this problem was solved when the ignition coil was replaced by the ignition coil, especially in vehicles fitted with LPG. They changed it to 250 TL. |
| 08.05.2020 14:10 | # 13 |
It was the same in the morning, I went to work in the morning, I went to work with a shaky warning or something.
| 08.05.2020 14:10 | # 14 |
sercinho |
The part of the mrb car, called the oxygen probe, seems to have malfunctioned, this adjusts the mixture.
| 08.05.2020 14:10 | # 15 |
Let's come to the solution ... or you will buy a new one, the cheapest is up to 350 TL. 1500 TL ... Solution 2 If you know where and what the catalytic converter is, you will disassemble and clean dozens of millimeter holes in the converter ... unless these blocks inside the catalytic converter are broken or dispersed ... You will disassemble the 3rd solution and attach a muffler to your master and leave as much greenhouse gases as possible. catalytic converter acts as a filter for the poisonous gases resulting from combustion from the engine.
| 08.05.2020 14:10 | # 16 |
Get well, I have the same fault. They replaced the ignition coil, it got better.
| 08.05.2020 14:10 | # 17 |
djchaos |
A problem that usually occurs in lpg cars, when I bought my car, I canceled the floor but now I wish I did not do it, I think it is a piece that prevents the damage to the environment.
| 08.05.2020 14:10 | # 18 |
[QUOTE = djchaos] A problem that usually occurs in lpg cars, when I bought my car, I canceled the floor but now I think I wouldn't do it, it is a piece that prevents the damage to the environment. I would definitely not recommend canceling the floor. [/ QUOTE] After a certain km, you will either install a brand of catalysts that you do not know if you have paid a lot of money, or you will have to disassemble it and install a muffler. This is the end of all catalytic cars.
| 08.05.2020 14:10 | # 19 |
The warning you say is that the oxygen sensors that can be removed in all malfunctions are divided into 2 upper and lower. The front service is 403 lower 410 lira in the authorized service ... around 90 to 150 in the side industries, but I do not think that the malfunction can cause this ... antipolituon fault letter will burn as the head blows. |
| 08.05.2020 14:10 | # 20 |
djchaos |
[QUOTE = yavuz25] [QUOTE = djchaos] A common problem with LPG vehicles, I canceled the floor when I bought my car, but now I think I wouldn't do it, it is a piece that prevents the damage to the environment. After a certain km, you will either install a brand of catalysts that you do not know if you have paid a lot of money, or you will have to disassemble it and install a muffler. This is the end of all catalytic cars. [/ QUOTE] ![]() I dismantled at home, I put it back on the inspection day and after the examination, I disassemble it, even if it is already attached. |
