Catalytic Converter Error
08.05.2020 18:44 # 1
eross
Friends first Hi there, a lot of time is the internet to enter when I could not forum also follow edemiyordum.arkadaş are way too LPG me this search tool " Catalytic Converter Failure to" give We began error only LPG also gives the car stops executing the error in gasoline, LPG ate taken by Catalytic Converter The car gives the error is running shaky at idle. I did not go to the master, but I wanted to ask you why this error could be, does it cost a lot?
08.05.2020 18:44 # 2
samet2461
You are my master Trabzon. It may be because there is an imbalance in vehicle lpg settings. If you don't have a master, there is a automative and I can direct you there in the big industry. Smile they are knowledgeable and take care of it.
08.05.2020 18:44 # 3
eross
Friends went to my industry master today, to find out where the ' Catalytic converter fault' error my car came from. I had the maintenance of my car's spark plugs, oil, oil filter, pollen filter, air filter changed and cleaned the throttle, but when I get the car to lpg, it still gives the Catalytic converter fault error, there is nothing in the gas but the vehicle does not fluctuate but the engine seems My master sibops, who are caring for my vehicle, may have kept the institution as if it is shaking a little too much. eross 2014-08-09 15:57:32
08.05.2020 18:44 # 4
derman362
1.First, have the butterfly cleaned, the maf sensor, air flow meter, fuel pressure sensor etc. I would like to have the sensors checked and adapt.
If not Resolved
2. Take out the lampta sensor and put it on, try bidet die, if it is not resolved, you will give it back, but it is most likely in the injection system, that is the first subject I told ...
08.05.2020 18:44 # 5
canbulat55
The subject has been opened 1 year, probably the problem has been solved, at least, I write that there would be additional information to the friends looking at this title. The same problem was in my vehicle. we can remove it one by one and control it according to the reaction of the engine. When we remove the socket, if it kicks more, that coil is working, but when we remove the socket, if there is no reaction from the engine, that coil is not functioning. It happened to me last week, we solved the problem in this way. If I am wrong, correct it. I hope it will be useful for someone ...
