Catalytic Converter Error
08.05.2020 14:54 # 1
diabolicfb
Hello there,
My problem is this;
On 29 September, I had my exhaust inspection done. On the same day, I ran out of gas (I always buy a shell) I went to the Cevizlibağ PO station. I bought 10 pounds of gas 30 pounds of gas. In the meantime, I gave a "catalytic converter fault" in my car before 5 or 5 hours.
The next day there is nothing 3 October today, the same mistake again, the vehicle idle is falling. It eats gas but traction stops at zero ramp. I investigated this error, but I could not find a clear answer, thanks in advance for your help.
diabolicfb 2010-10-03 19:45:40
08.05.2020 14:54 # 2
Firstly, get well soon.
I also had a similar malfunction. Catalytic converter wear was giving error when I connected it to the computer. I was getting on and saying that nothing would happen. One week after I had the tube installed, I took a look and the car is not going to kick. Although I stepped on the gas to the end, it started acting as if there was no engine in the car. I removed the exhaust containing the converter to a good engine master in the industry and then cut the part where the catalytic converter was located. we smashed our catalytic with a wooden wedge Sırıtma Even if the master said this minced meat, I said that if you do not do it, I will withdraw and it will break down after two days. Thanks to my master, he took a wedge with a wedge. Currently he works a little too loudly. I am looking for an alternative solution, but I cannot find it. I think there is an alternative with a silencer for diesel engines, the price is around 150 lira, but I do not know if it will fit gasoline. If you empty it, I would be glad if you write what solution the catalytic converter found because its sound makes me nervous. Especially when I enter gasoline, I am crazy when they say LPG diesel on the other side.
I am waiting for your solution. Again get well soon.
08.05.2020 14:54 # 3
diabolicfb
As a first car, it was a great comfort and convenience, but I also chose a car that made it so familiar with the problematic mechanic. Now I realized something, I went, I said I would look at the car again, I took 2 rounds, I came, there was no trace of the fault, I got into the traffic of the bridge on the first day. Today I was in stop-and-go traffic again and the temperature was over 90. The man who was going to beat my father when he said that :) now we've reinforced his water. But it was certain that when the temperature increased. Now, there is no error, of course, there is no mistake, but I will look at the mechanic, but I will wait for those who have ideas to share again. Thanks
08.05.2020 14:54 # 4
alp34
brother, the only problem you will check in 307 is that it is not the same circulation pump is the same problem that you have the temperature you have in me, the only caste is in circulation pump is not a problem in your vehicle.
08.05.2020 14:54 # 5
diabolicfb
Hi
We took the vehicle to the mechanic yesterday, thanks to my car, it took 220 TL by changing the ignition coil system in the past, without disturbing the reception. :)) That's the reason for my "catalytic converter fault". Of course, if there is a problem in the temperature system that this master said and burned the coil, it is worse. In one vehicle, the vehicle consumed excessive petrol, 20 TL gasoline in the in-line system did not go for 10 days. He said the reason is bobbin. Let's see. I'm best to sit and update my signature.
diabolicfb 2010-10-05 08:50:49
08.05.2020 14:54 # 6
I will not assert you again as usual, but I was very curious about what the coil has to do with the heat of the vehicle. I think you're wrong with a master and come to my face. If your vehicle overheats, the water will boil. I think your vehicle's not overheated. Even if the car was really overheated, it shouldn't be something. Maybe it will be broken when it is broken, it is also a separate subject ... temperature is normal until 100C & nbsp; & nbsp; it is ok. The temperature is 120 120s and steam is spraying out of the lid ... If your vehicle has a temperature problem, you will be able to overcome the cooling system ... Your head will be comfortable ... .
08.05.2020 14:54 # 7
diabolicfb
It could be, maybe it was broken. As I said, the temperature increased, 90 of them were light, so 100. Perhaps I may have built the heat coil combustion relationship because it coincided with my head. I don't know, I'm going to try the gasoline event for a while, first I will heat the engine, switch to gas and then start using it. Thanks for your attention, 307 has been a painful but full of experience for me. It cools me more and more, but I ride stubbornly :)
08.05.2020 14:54 # 8
I think you will consume even more gasoline if you think you will try it ... why do you think you should try this way? A lot of gasoline will burn until the engine warms up. the goal is not to switch to lpg as soon as possible. also, & nbsp; after starting the vehicle, there is no point in waiting where it is until it gets warm. Meanwhile, while you are heating up, you will go some way with your gasoline. It is not important to heat it where it is an intermediary. I will understand that it will be very cold and snowy, then… I do not rotate until it is hot ... so my gasoline has been between half a quarter and a long time ...
08.05.2020 14:54 # 9
12omantic
brother, I have been having the same problem for 2 days. I wonder if mine is also from the coil if they tell you they will do it from the spark plugs.
08.05.2020 14:54 # 10
diabolicfb
Hello,
& nbsp;
The vehicle was starting to overheat in areas where traffic was normally jammed. Because I had not seen the vehicle overheat in bridge traffic before. I took it to the master and said on the phone without taking it, he said it burns LPG vehicles. Perhaps burning the coil caused fever. Friends say irrelevant. But your problem & nbsp; is probably from the coil. I think I bought it for 220 TL, excluding workmanship. In addition, the failure of this coil increased the consumption of gasoline. Does your vehicle burn a lot of gasoline even if it has LPG? it just uses gasoline to run but it burns me too.
08.05.2020 14:54 # 11
Gasoline is not only used to run. it changes from vehicle to vehicle. Because the night temperature value set in each vehicle and the time it takes to reach that temperature can be different. I will not assert again, but I have not seen the vehicle that has gassed as fast as mine. Because the night temperature is set to 15C. the masters raise the heat of the night to 40 45 50. they can drop towards 30 in summer. they usually cost around 40. There's a reason for that. If it is necessary to explain it very hardly, the adjustment event, which we call automatic calibration, works only according to the warm color values. If it is changed manually in carpan, it affects the hot run to the event. but the working conditions are different when the engine is cold. The lpg pharmacy does not know the cold working conditions. When applied, it always applies the warm color settings of the engine. Since the engine mixes early, the fuel mixture is unbalanced and the engine starts to jump to hop, so it does not work properly. the masters raise the heat to overcome this problem. Because of the 45-50 C, when the engine runs hot when it runs close to the values, it will not be a problem when it reaches lpg ... this is a very simple solution. you will watch it with gasoline until it reaches this temperature. In a short time, this means the consumption of a serious gas. many people say they burn less at lpg. But on the other hand, they consume a serious gas. but they don't take this into account. I will consume LPG where I will consume gas. While watching the others with more gas, I would have switched to multi-lpg. I consume very little gas from this pain ... at the same time, masters have a thought in mind. I have a problem with the vehicle, somebody broke down, if there is lpg, they immediately stick the "lpg stop" phrase. :))) cecoli2010-10-08 11:01:25
08.05.2020 14:54 # 12
diabolicfb
I think you're right. Especially before plugging, I have researched a lot, but LPG fitting is not suitable for peugeot. I say the coil was going to be broken, I say I don't mind what the master says or people say this is a problem. I love my car, I think it must have been because my car, which approached 100,000, had not received such attention before me. I try to solve every problem that I can enjoy more. I even changed the key with my eyes closed. It is not known what time it is but ..... I am also happy to see this title. I looked at the internet for days, it has never written a problem explaining this error clearly ... diabolicfb 2010-10-08 14:46:08
08.05.2020 14:54 # 13
Happy if you found the solution to your problem ...
08.05.2020 14:54 # 14
12omantic
friends, 125 TL from the sub-industry of the coil is what you can trust, I can not trust what it is, but after all, it is guaranteed when it is done in the service. I'll take a coil and put it somewhere in the industry
08.05.2020 14:54 # 15
BAHTIYAR
I have heard that LPG has burned the coil. Fortunately, I do not have anything in my friend's vect. It happened 2 months after the LPG was installed.
08.05.2020 14:54 # 16
diabolicfb
@ 12omantic Hodja is a difficult choice. No, let me go to the service. If the pattern burns again after 6 months, they will say that it has nothing to do with us. This is also annoying, but if you get stuck in the industry after 6 months, it seems most reasonable to look at the pouch that is suitable for the pouch, at least as soon as you take care of it, this will be burned. I bought the part original, but I had it installed in the industry. You found it good at that price
08.05.2020 14:54 # 17
amores
Good morning,
& nbsp;
This morning the catalytic converter fault message appeared in my car, the car started to shake and not get gas ...
I have been using it for about 1 year. Does anyone know why it is caused?
My car is 2004 model 307 LPG li ...
08.05.2020 14:54 # 18
Do you get it fixed when you get it on the gas or did you see this error on your gas ??
08.05.2020 14:54 # 19
amores
Already the car runs with the first gasoline, then passes to LPG, and gave this error when the car first started.
08.05.2020 14:54 # 20
just plug it in and see if it will do it again? If he does, where and how does he watch ...
Page : / 2
