"Catalytic Converter" and "Anti Pollution" errors
08.05.2020 17:23 # 1
spark_ugur
Hello everyone,
2005 model 307 1.6 XR - I get" catalytic converter fault "and" antipollution fault "errors in my LPG vehicle. The vehicle falls out of traction and stacks. The vehicle is blowing smoke from the exhaust in the form of "pat pat". & Nbsp;
It will be 20.000 kilometers with LPG replicator. The proposed solutions to me are:
1-replace catalyst.
2-clean catalyst.
3-catalyst cancel catalyst replace pipe.
4-replace ignition coil.
I'm waiting for your help.
08.05.2020 17:23 # 2
ahmetismet
I think if you look at the spark plugs and you haven't changed them recently, there may be rust.
08.05.2020 17:23 # 3
spark_ugur
It's been 1 month since I changed the spark plugs of the car. I don't think it will be from him ..
08.05.2020 17:23 # 4
scorpion_enis
Hello, it happened to me. I changed the spark plugs first, then I changed the ignition coil, it improved. But look at the lpg injectors, one of my lpg injectors was out of order.
08.05.2020 17:23 # 5
spark_ugur
As I mentioned in the message,
the vehicle only gives problems in rainy weather. At the moment, they called me in the service and the vehicle was not a problem. (it didn't rain my luck) (
08.05.2020 17:23 # 6
fatihgg
It does the same with the fuel you buy and the air flow meter.
08.05.2020 17:23 # 7
spark_ugur
pain in the computer: catalyst igniter failure - consecutive same faults.
I don't know the codes, unfortunately.
08.05.2020 17:23 # 8
elsoberano
I bought the same fault over the weekend, I had oil maintenance 15 days ago spark plug all the filters changed. I continued to use it and then the fault lights went out. There is no problem in the work. It has not been repeated for 4 days. I think it may be related to the fuel.
08.05.2020 17:23 # 9
emin15
If you can get the codes on the computer, we will give you more clear information
08.05.2020 17:23 # 10
spark_ugur
I WRITE THE FRIENDS ERROR CODE:
P1340 - EXCLUSIVE FAILURE IN THE CYCLE 4 DISORDERS
P1336 - OVER-COMBUSTION FAILURE IN INTERRUPTED FAILURE CYLINDERS
TELL ME TO RIDE ME ON THE VEHICLE, THERE ARE STILL NOT DETECTING THE FAULT AND THE PROBLEM IS CONTINUING ..
08.05.2020 17:23 # 11
spark_ugur
[QUOTE = emin15] If you can get the codes on the computer, we will give you more clear information [/ QUOTE]
P1340 - CONTINUOUS EXTREME BURNING DISORDER IN CYLINDER 4 CYLINDER
P1336 - EXCLUSIVE FAILURE IN INTERRUPTIVE FAILURE CYLINDERS
TELL ME NOT TO RIDE ON THE VEHICLE ER AND THE PROBLEM CONTINUES ..
22.11.2021 16:02 # 12
berkant12
Hello sir, has the problem been solved, the same problem has been going on for 2 months for me. No one can detect the problem, everyone says top cover. But we put the sensors that I mentioned below to come off, the shaking problem in the car and the p1340 warning goes away instead of the sensor failure. I think the sensors are incompatible, that's why we said that the malfunction lamp is on. ORIGINAL ZERO I bought 3 sensors that I specified. The absence of vibration from the removable part, the shaking of the car in the zero part, I am waiting for your help for the abnormal solution ( ANKARA )
1920.LS ( CAMSHAFT SENSOR 2 PCS < /div>
1628924280 ELECTROVALVE SENSOR 1 PCS (on the front)
http://www.w3.org/2000/ svg" viewBox="0 0 47.94 47.94" width="16px" height="16px" fill="#dddddd">http://www.w3.org/2000/svg" viewBox="0 0 47.94 47.94" width="16px" height="16px" fill=" #dddddd" style="margin-left: 2px;">http: //www.w3.org/2000/svg" viewBox="0 0 47.94 47.94" width="16px" height="16px" fill="#dddddd" style="margin-left: 2px;" > http://www.w3.org/2000/svg" viewBox="0 0 47.94 47.94" width="16px" height="16px" fill="#dddddd" style="margin-left: 2px ;">< /svg>http://www.w3.org/20 00/svg" viewBox="0 0 47.94 47.94" width="16px" height="16px" fill="#dddddd" style="margin-left: 2px;">
< div ="jq-ry-rated-group jq-ry-group" style="-sizing: border-; outline: n one !imant; : ; line-height: 0; : 2nd; white-space: nowrap; width: 0px; ball: 0px; left: 0px; overflow: ;">http://www.w3.org/2000/svg"< /a> viewBox="0 0 47.94 47.94" width="16px" height="16px" fill="#FFBB00">http://www.w3.org/2000/svg" viewBox="0 0 47.94 47.94" width="16px" height="16px" fill="#FFBB00" style="margin-left: 2px;">http://www. w3.org/2000/svg" viewBox="0 0 47.94 47.94" width="16px" height="16px" fill="#FFBB00" style="margin-left: 2px;">http:/ /www.w3.org/2000/svg" viewBox="0 0 47.94 47.94" width="16px" height="16px" fill="#FFBB00" style="margin-left: 2px;"> http://www.w3.org/2000/svg" viewBox="0 0 47.94 47.94" width="16px" height="16px" fill="#FFBB00" style="margin-left: 2px;">
< /div>
