Catalytic Converter
08.05.2020 17:45 # 1
myvzklc
Friends took my car to the exhaust yesterday, the converter said it had to be changed under decay. The price was around 800 TL. Is there a place where I can get this piece more suitable? I'm waiting for your help.
08.05.2020 17:45 # 2
soner09
I say try it out from the owner or the brothers.
08.05.2020 17:45 # 3
emp
Is your vehicle lpg li?
08.05.2020 17:45 # 4
myvzklc
Yes Brc Lpg Available
08.05.2020 17:45 # 5
emp
You pollute the already pouring environment less than using gasoline. My advice to you is to cancel the catalyst and replace it with a silencer similar to a catalyst. When you pull back the oxygen sensor a little bit, your fault light will not burn (there are ready-made bolts or you can combine several bolts and do it yourself). It stays around the gasoline model in your emission. It will be an economic solution for you.
08.05.2020 17:45 # 6
myvzklc
So, would canceling this catalyst damage the vehicle?
08.05.2020 17:45 # 7
elsoberano
I have the same problem. they said that we can not put out the pain when we cancel the pain because it is a double sensor. They said that in case of cancellation, you can experience lower performance and increase in fuel at lower speeds. I got a price from 3 places.
08.05.2020 17:45 # 8
myvzklc
They said they have 150 TL.
