Catalytic Converter
08.05.2020 15:54 # 1
vbmaster
Friends, I am obsessed with the excessive burning of my vehicle. He told the following about the master (from the head of the authorized service master, who has kelli feli) burnt the fallow.
1. Generally, nozzle nozzles are widened in vehicles exceeding 100 thousand. over time it discharges fuel. they do not recover with this cleaning, they are physically degraded. the one that changes it will surely pay you as fuel.
2. Coil spark plug lamda etc. in the ignition system. Any failure in the parts will cause excessive burns.
3. The small but arm-priced handlebar that holds harmful substances, called Catalytic Converters, will burn more than dollars, which is already around 150 thousand dollars. it will definitely return to you as a fuel saver.
Now I assumed that I took care of the first 2 choices, I said I could go into the convertible event and they said 650 million. I found the original in midwifery 80 pounds. Britain. With the cargo that comes at half price, even less than half, around 220. Can we come to the cripple, do they print customs? Is there any equivalent to the tax here, or how many and my most important question DOES THIS TOOL DIFFERENCE IN FUEL? :)
thanks ...
vbmast is 2011-07-29 01:50:02
08.05.2020 15:54 # 2
ereneren
11 years old, if the car runs out of here, I think the handling is ...
08.05.2020 15:54 # 3
Emre Ekrem
it may not be stuck, it is not certain, sometimes it is stuck, in any case it is guaranteed to come cheap.
08.05.2020 15:54 # 4
We did not add the heat of the converter to your head. They have 250 to 300 lira side industries ...
08.05.2020 15:54 # 5
insomnia
[QUOTE = CeCoLi] We wouldn't let the converter heat into your head. They have 250 to 300 lira side industries ... [/ QUOTE]
cem master, look at me now, these injector nozzles or injectors should change how many thousand of their average lifespan and what is the price range, if you inform us, it will be much appreciated.
