Catalytic Converter
08.05.2020 18:18 # 1
gebedek
Hello friends. Is there anyone who has catalytic converter problem in 206? How did you understand the question and what did you do for the solution?
08.05.2020 18:18 # 2
dukenukem82
A car does not pull, a shimmer comes from the exhaust. Take your lighter and put it on. I had no problems since the oxygen sensor was single.
08.05.2020 18:18 # 3
herry
Connect it to the computer, take your car out if there is a problem, and if it is very dirty, the engine can also light the mouth.
08.05.2020 18:18 # 4
gecegoz
[QUOTE = pregnant] hello guys. Is there anyone who has catalytic converter problem in 206? How did you understand the question and what did you do for the solution?
Brother, first of all, if you write in more detail, we will try to help you ...
08.05.2020 18:18 # 5
ekinoks44
I could not have an exhaust inspection due to the catalytic converter. I have removed the catalytic converter of my vehicle so I think the lpg would be better. Now I'm having trouble with exhaust inspection. According to the mechanic, the price was around 1000 TL for the new one. Does this catalytic converter, which I don't understand, do anything but environmental pollution prevention?
08.05.2020 18:18 # 6
gebedek
Thank you for your attention. I work in a remote village in the district of Ardahan, and nobody understood the problem here. The vehicle works after 5 minutes of cranking in the morning. Sometimes it doesn't work on petrol, Lpg also works. Even when I run the gas for two minutes when it starts, the vehicle does not go. It gives rich fuel failure in the computer. But after the vehicle warms up, it runs on one starter and there is no problem of not moving. This has been the case for 5 months.
08.05.2020 18:18 # 7
gebedek
Meanwhile, gas consumption of the vehicle has increased a lot. The vehicle is lpg but every time it consumes lpg gasoline. Also, when I stop the vehicle, smoke continues to come from the exos. Tonight the weather was very cold, the vehicle never worked.
08.05.2020 18:18 # 8
yawruaslan
[QUOTE = pregnant] In the meantime, gas consumption of the vehicle has increased a lot. The vehicle is lpg but every time it consumes lpg gasoline. Also, when I stop the vehicle, smoke continues to come from the exos. It was very cold tonight, the vehicle never worked. [/ QUOTE]
Have you canceled the solid, let me try it so maybe it would be useful, if it is very dirty, it may be strangling the vehicle.
