Catalyst problem |
| 08.05.2020 14:58 | # 1 |
As a teacher friend went to work yesterday morning, 307 vehicles suddenly wrote a catalytic converter malfunction on the trip computer and the engine part of the vehicle trembled. bo continued until the breakdown went to the workplace. When he went home in the evening, he started the car and went to his house without any problems - he traveled with his car today, but the same fault did not occur again --- as you know, very expensive in catalysts. Today, they connected the computer to the peugeot service with a friend, there was no problem - what could happen to you?
| 08.05.2020 14:58 | # 2 |
evren307 |
If gasoline is low, the remaining gasoline residue can cause it. I think it will pass after filling the gasoline. |
| 08.05.2020 14:58 | # 3 |
what you say may be true. your friend's car was lpg and the gas gauge was at the bottom ...
| 08.05.2020 14:58 | # 4 |
If lpg, it may be due to a mixture error ... it was lpg at the moment of giving this fault and let's look at a problem ... or does it do the same when it is in its compassion ???
| 08.05.2020 14:58 | # 5 |
They went to work like early morning (7:30) and when the vehicle was on LPG but did not happen during their next run ... they said in the service "let me know when the malfunction occurs.
| 08.05.2020 14:58 | # 6 |
If a temporary malfunction occurs, ecu may sometimes not register. I think it may have been a situation like this ...
