CATALYST PROBLEM
08.05.2020 14:59 # 1
kizilhakan
HELLO FRIENDS THE MOTOR IS FAILED BEFORE STARTING TO BE SURROUNDED IN MY VEHICLE, THE MOTOR IS FAILING THE FAILURE.
08.05.2020 14:59 # 2
erk
Search in Google for the cancellation of the floor, you will see good results :) Only in every place in front of you, this process is not done Lambda sensor must stay in place. powers 2010-12-08 11:34:34
08.05.2020 14:59 # 3
or you can attach the side industry to the floor with a rope string ... 500-600 TL
08.05.2020 14:59 # 4
erk
[QUOTE = cecoli] or you can attach a side coat with a string of rope ... 500-600 tl around [/ QUOTE]
This is also an option, but there is always the possibility of opening the same problem again.
08.05.2020 14:59 # 5
[QUOTE = erk] [QUOTE = cecoli] or you can attach a side coat with a string of rope ... 500-600 TL around [/ QUOTE]
This is also an option, but there is always the possibility of opening the same problem again [/ QUOTE]
of course ...: DD
