carptim into the car on my way back
08.05.2020 19:33 # 1
mjtanju
http://i.hizliresim.com/7xnyal.jpg
Hello there. bunlamba was burning only one by one was broken. :) What is the name of this lamp? Thanks
08.05.2020 19:33 # 2
Get well, my teacher goes as 206+ rear fog lamp, that piece has a price of 80-100 TL. it does not cost more than 10-20 TL for mounting, but if you can, you can do it. sonerkyl 2015-12-15 09:46:44
08.05.2020 19:33 # 3
KILIC
If one is lit, it is a fog lamp.
08.05.2020 19:33 # 4
mjtanju
Well, if I did not change the original of this car, there would be a problem in the inspection. The lamp was not broken. In the dark I was going back to the side in the dark and the back was steamed and I couldn't see it when the parking sensor didn't sit down: /
08.05.2020 19:33 # 5
I don't think there will be a lot of trouble. I know that there is no crack problem. if it is broken, they do not spend. Of course, experienced friends and writers answer about it
08.05.2020 19:33 # 6
mjtanju
I hope I couldn't find it on the internet
08.05.2020 19:33 # 7
serdaralisan
the back fog lamp of my friend, this is the reflector called cat's eye on the side where you mark the red on the right side, there is a light bulb on the left side.
08.05.2020 19:33 # 8
samet206
These are the rear fog, as far as I know, some cars do not light up, while others are activated and not install bulbs etc.
08.05.2020 19:33 # 9
mjtanju
[QUOTE = if you are serdarra] the back fog lamp of my friend vehicle is the reflector called cat's eye on the side you have marked on the red on the right side, there is a bulb on the left side, when you turn on your fog, it will burn, crack, just make a transparent film on it, it may be red or transparent, but if it is broken, it will not go through the examination.
the place with the light bulb on the left was broken, it was not burned, but it was not touched :) just like you said
08.05.2020 19:33 # 10
serdaralisan
no history, no broken, and if the lamp is burning, no problem goes through the examination, I used to work on tweezers but new laws have been passed, for example, sports post-mounted steering wheels are no longer considered as a serious defect, so do not sell your original steering wheel friends
