Care Materials Taken for 308
08.05.2020 17:58 # 1
kemalakkan
Greetings, friends, I finally got 308 but I need to do the maintenance urgently. I will get the price of 75 amps from th accumulator, I will write the price
1-SPARK PLUG EP6 TYPE 5960.L0 4 PIECES 15X4: 60 TL
2-AIR FILTER 1444, XG 1 PIECE 25.42
3-POLY FILTER WITH CARBON 1 PIECE 29,66
4-OIL FILTER 1109.CK 1 PIECE 14.41
5-GASOLINE FILTER 1 PIECE 12.71
6-REAR WIPER CLEANER 1 PIECE 12.71
TOTAL DISCOUNT 93.22
VAT 18 16.78
TOTAL 110 TL
08.05.2020 17:58 # 2
kemalakkan
Greetings I have CASTROL 5w30 EDGE, I will use it when I say the belts, I will change the battery, I have 75 amperes of formula, I would like to take care of it because it is already 1 year since the vehicle has been in maintenance for 30 thousand km in 34 thousand years and I would like to take it.
08.05.2020 17:58 # 3
kemalakkan
Believe me, I did not pay attention, I will change it anyway, I am meticulous, a little bit about it. My car did not work today. I guess the battery is over now. There is a bit of pearl battery. 75 amper pearl formula is 75 amperes.
08.05.2020 17:58 # 4
hsnsnl
I recommend you to check the prices of this place for the battery ..
http://akufiyatlariizmir.com/index.php?route=product/category&path=35
08.05.2020 17:58 # 5
kemalakkan
Thanks for the really affordable prices
08.05.2020 17:58 # 6
kemalakkan
Greetings, friends, I did not want to open a new title, I said, let me write it here. OIL also appears in 308. I changed the oil , I changed the oil, I put 4 liters of oil.
08.05.2020 17:58 # 7
hsnsnl
If the vehicle has stopped on the ground, the teacher will do it, put it on the ground, cut the vehicle and fix it after half an hour.
08.05.2020 17:58 # 8
Serkan
The most healthy one is to measure from the dipstick, wait 1-2 hours on a flat surface, then pull the dipstick and check if you are missing.
08.05.2020 17:58 # 9
kemalakkan
Greetings, friends, I checked the oil, as you said in the vehicle, if there is something left on the slope .. but I want to ask something else, now the lamps of my vehicle are on the automatic but I want to turn it off while my vehicle is working.
08.05.2020 17:58 # 10
Serkan
I am the same teacher, even if you bring it to zero while the car is running, it doesn't go out, you have to stop it to go out
08.05.2020 17:58 # 11
kemalakkan
What is the reason, so I need a software update, mine for this vehicle is 2008 model vti premium
08.05.2020 17:58 # 12
hsnsnl
auto headlights cancel my professor ole you turn off your headlights other types of active headlights are always active .. you can turn the headlights by turning them into parks
08.05.2020 17:58 # 13
kemalakkan
Greetings, friends again, I also congratulate your sacrifice feast. Another question I would like to ask is that I changed the car's blades last week, now it takes a little night when I start the car.
08.05.2020 17:58 # 14
Serkan
Is there a lpg in the vehicle?
08.05.2020 17:58 # 15
kemalakkan
Unfortunately, there is no LPG in the vehicle, but even though the oil is OK, it feels strange to write.
08.05.2020 17:58 # 16
Serkan
I also had the first starter working late, sometimes even the first starter did not work at all, but the next starter did not have any problems, but I have LPG and LPG injectors changed, the problem is solved, when I say oil, it just says Oilmi, does not it write anything else? When you turn on the first contact, if it says in the meter, it gives a warning like OIL PRESSURE LOW on the screen of the trip computer if the tree decreases the oil .
08.05.2020 17:58 # 17
kemalakkan
Now it is occasionally oil ... It says normally, oil was writing ok, but when I wrote it, I wanted to ask it, it is not missing in the oil. It is not stuck in my head, so I am satisfied
08.05.2020 17:58 # 18
Serkan
If it looks exactly from the dipstick, you shouldn't wear too much, by the way, is your vehicle 110 hp? What does fuel burn, hojam? My vehicle is like a lot of fuel at 110 lpg, I have never tried it on gasoline
08.05.2020 17:58 # 19
ahmet_bjk
As the amperage grows, the size of the battery grows as well.
08.05.2020 17:58 # 20
Serkan
[QUOTE]
Cik :) I have 4 more years to sell :)
Page : / 2
