Care has come but
08.05.2020 15:30 # 1
My friends vehicle has reached 65 thousand, the wrench sign indicating the maintenance has been lit up.
yesterday turned the ignition first, 100 km of the remaining diode, bugn 200e, I did not understand this work ..
It fell from 900 to 100, now it is 200 again.
Is there anything like that?
the albaydemirc 2011-05-29 11:43:31
08.05.2020 15:30 # 2
oguzhan29
If my brother has increased that burn, it will burn in kms of maintenance every 100 km
08.05.2020 15:30 # 3
yes, it has increased.
What should I do as a maintenance now.
timing changed previously, oil filter changed, air filter changed ...
only oil left, brakes, front gear etc
08.05.2020 15:30 # 4
Repeat the air filters. oil oil filter. oil filter. pollen filter.
08.05.2020 15:30 # 5
While I am changing the bidet oils, I will change the steering to hydraulic oil.
I cannot change the diesel filter because my feline is gasoline :)
08.05.2020 15:30 # 6
pardon Sırıtma I got it, I went so
08.05.2020 15:30 # 7
not important kenan brother :)
If you have a diesel, you will make a diesel immediately :)
facemelow to 2011-05-29 01:57:42
08.05.2020 15:30 # 8
Did you change the oil filter without changing the oil? Tell the master when he has an oil change, he'll reset it.
[QUOTE = facemelowe] yes it has increased today.
08.05.2020 15:30 # 9
If You Have Carried Out Its Maintenance Soon ...
Hold Instant Momentary and Indicator Light Button for a Few Seconds at the Same Time, It Will Fix Itself ...
08.05.2020 15:30 # 10
Reset after changing oils. Or you can forget.
[QUOTE = ezelefe] How to reset it in the forums is written.
As far as I can remember, you kept the ignition pressed, while you kept the ignition off, you were doing it from there.
