carbon filter kit
08.05.2020 17:34 # 1
onur07
Does anyone use the product in the announcement? Do you think it would be useful, what are your views?
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-aksesuar-tuning-otomobil-arazi-araci-peugeot-pejo-206-carbon-karbon-flitre-kit-filitre-kiti- 206-123774836 / detail
08.05.2020 17:34 # 2
umut_25
I am thinking of buying it. Friends who use and have knowledge will write your opinions.
08.05.2020 17:34 # 3
outlaw
I think they usually wear it for sound rather than performance, this is referred to as a boiler filter, but if you ask for my opinion, a quality filter with an extension pipe will get much better results, for example I did.
We installed a seven-brand filter with accordion pipe, the car was badly pulled ...
08.05.2020 17:34 # 4
onur07
Do you have the advertisement of the product you mentioned?
08.05.2020 17:34 # 5
Aziz
[QUOTE = outlaw] I think they usually wear it for sound rather than performance, this is called the boiler filter, but if you ask my opinion, you will get a much better result with a lengthened pipe, for example, I did it ...
I did this too, accordion pipe and filter,
sample
products,
08.05.2020 17:34 # 6
Aziz
Or it seemed more affordable as this price :)
08.05.2020 17:34 # 7
outlaw
There is the same in me as our saint friend did ..
you can extend the filter wherever you want ...
My dear brother, but don't let the filter hang down GOD bless you will have trouble if it draws water ...
08.05.2020 17:34 # 8
fexzi
accordion pipe cuts the air due to the layer, you reach more precise solution and better quality performance & sound with smooth surface.
08.05.2020 17:34 # 9
Aziz
[QUOTE = outlaw] I have the same as my dear friend did.
Yes I corrected this first picture after looking up already. I am trying to set the positions to move the pipe and make it longer, warn and thank you for your interest.
Pay attention to the information of my honor friend, our fevzi master touched on a nice point, but I could not find the straight pipe of the length I wanted and I chose accordion because I could not fit it :)
08.05.2020 17:34 # 10
onur07
Thank you for your valuable information, I will be careful to make an assembly for what you say, and as far as I understand, the pipe will be more healthy by extending it to what it can be.
08.05.2020 17:34 # 11
Aziz
I wish the best.
It extends the pipe so that the purpose is to absorb cold air;)
08.05.2020 17:34 # 12
onur07
thank you .... I also want to ask about this may not be related to the subject, but the engine is very hot and the fan that I pay attention to does not work? (fan at the top of the plate) was activated after a certain heat
08.05.2020 17:34 # 13
fexzi
If possible, wrap it carefully with the heat insulation tape, even if you direct it to the places to breathe, the engine part will create a hot area, and the appreciation that you minimize it will be effective.
08.05.2020 17:34 # 14
Aziz
[QUOTE = onur07] thank you .... I also want to ask about this may not be related to the subject, but the motor is very hot and the fan I paid attention does not work? (fan at the top of the plate) was switching on after a certain heat [/ QUOTE]
I'm sorry to ask you how do you follow the temperature of the engine,
The thermostat and the temperature sensor that will activate the fan do not know how many degrees it is, but I think it should be activated at 95: If the S does not enter, the stop warning lamp lights up in the instrument panel.
08.05.2020 17:34 # 15
onur07
When I opened the hood to check its water, I realized that it was extremely hot, although I did not go too far, I will go to the service for torsion tomorrow, if I have a sign, we will fix it.
08.05.2020 17:34 # 16
umut_25
Pejo, as I know it, is already a hot engine. I don't think there will be a problem if the temperature indicator is normal. There is no problem in the thermostat. Because if there is a problem, Fan does not come on. If the fan does not come on, it will be hot. The fan comes on, cools down, then turns off. What is the heat?
08.05.2020 17:34 # 17
onur07
Since my temperature is okay, it means that the engine you are talking about is running when it is hot ...
08.05.2020 17:34 # 18
herry
[QUOTE = onur07] anyone using the product in the announcement? Do you think it would be useful, what are your views?
the product in this announcement is a product of simota carbon flashing, the original of the same commodity does not write 206 on the same, you may get sound from this type of mirror products, but don't expect performance. even your lower cycles will be anguish to you in this summer .. I have a lot of writing and experience on the air filter. Finally, I made my short ram system in the forum straight pipe, I am very pleased. Even if I use original parts, isolate the best and install it in the most comfortable places where it can get air, sometimes I lose power. I can't think of this type of products. directly use the car's orig filter + 4hp in the pocket
08.05.2020 17:34 # 19
onur07
thank you for the information
08.05.2020 17:34 # 20
herry
[QUOTE = honor07] thank you for the information it was very descriptive [/ QUOTE]
You are welcome, what do you mean, my friend?
Page : / 2
