car tuk sounds after the steel rim |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Modification and Tuning Information | |
| 08.05.2020 15:06 | # 1 |
| 08.05.2020 15:06 | # 2 |
friend who has no experience
| 08.05.2020 15:06 | # 3 |
You can have more information if you open the subject where the tactical sounds come from.
| 08.05.2020 15:06 | # 4 |
slm mate sounds have several reasons, one is big, the rims are rubbing in the lakes and the other one feels the troubles more in the undercarriage and can't get enough suspension
| 08.05.2020 15:06 | # 5 |
There is no rubbing, it does not come out on the straight road, but there is sound in the smallest pits.
| 08.05.2020 15:06 | # 6 |
alaaddin |
because of that sound, I replaced my 205/40/16 rim with 175/65/14 so now it doesn't make sound
| 08.05.2020 15:06 | # 7 |
but not in my 205 40 16 I was not exaggerated with the 185 55 15 I was wearing the room is an ideal size but this sound really disturbs me, I asked the masters, said the shock absorber did not break, did not break, did not break after installing the rim
| 08.05.2020 15:06 | # 8 |
masumserseri |
It is true if it is called master, it is true. There is 195/55/15 in my vehicle. There is no problem.
| 08.05.2020 15:06 | # 9 |
WHEN THE WALL SIZE IS SMALLENED, THE CAR BEGINS TO BE SENSITIVE REACTION EVEN IN THE SMALL PITS. THIS BECAUSE THE SOUND WHICH YOU WERE NOT HEARED BEFORE ABSORBING THE SOUNDS WHICH THE SIDE WAS ABSORBED. |
| 08.05.2020 15:06 | # 10 |
sercinho |
My friend is okay, in fact, you can reach this interpretation when you compare it with the one you used to, but you can understand the difference if you get the same rim and size in the same rim and the size of the rim can make a little bit of sound. First of all, undisturbed undercarriage and shock absorber rims do not deteriorate after fitting.
| 08.05.2020 15:06 | # 11 |
thank you very much, all of you guys, I will evaluate your valuable comments, I hope there is nothing in the shock absorbers, I should just wear a bow, I should not wear it, it would be nice if I could learn it.
| 08.05.2020 15:06 | # 12 |
should I wear bow do you think friends
| 08.05.2020 15:06 | # 13 |
I have 185/55/14, I changed the rim, I changed the shock absorber, and that sound still did not go, I guess, it is caused by sports spirals. Because the complete front set had changed, the motor, including the ears etc., is attached to the sports thick helix, so the life of the shock absorbers goes very quickly.
| 08.05.2020 15:06 | # 14 |
The tire brand has a sonar and I am not satisfied.
| 08.05.2020 15:06 | # 15 |
my front two rubber dunlop back one dunlop the other marshal so one might be a different man: D |
| 08.05.2020 15:06 | # 16 |
voodoo |
go to the master master .... or to the service ... if the sound comes from it, it can come from the swing pads, mine had the same problem in 6 months, I found it difficult ...
| 08.05.2020 15:06 | # 17 |
Muhammet CAKIR |
It is not from the rims brother, I wore it 195 * 50 * 15, I don't think it is the same as I used to be.
