CAR OIL MISSING
08.05.2020 18:38 # 1
medakilec
FRIENDS YOU ALL HAYIRLI DAYS, I LOOK UNDER MY CAR IGNITION SWITCH OFF AFTER OIL Or, you FUEL misses is exactly what I do not understand, I SHOW I TAKE AUTHORIZED SERVICE Both the oil and the FUEL LEAK HAVE SAID (OIL RAMP was going CHANGED SAID LABOR EXCLUSION Uttered 1,200 per COSTS, FUEL LEAK INSIDE possible ONLY ONE PIPES CONTROL EDİP LEAK's tHAT WHERE DETERMINATION wILL bE SAID, if TELL PIPE in that CHANGED ESTIMATED $ 2,000 OVER REMOVE tHE COST), outside USTA IF OIL LEAK in the SPECIAL SERVICE I MAKE MAINTENANCE iS FUEL DO NOT MISS SAID tHAT, OIL leak in that cOULD from CARTEL SEAL SAID. I SHOULD TAKE IT OUT FROM AN EXTERNAL MASTER, AND THE MOSQUE IS MISSING. I HAVE UNDERSTANDED IT IS IT HARD TO UNDERSTAND WHAT THE LEAK IS? THE LEAK ENGINE IS AFTER IT IS STOPPED AND STOPPED, I HAVE CHECKED THE OIL BAR AND OIL INDICATOR THE ENGINE OIL IS LIKE NORMAL. I CHECK THE FUEL CONSUMPTION.
08.05.2020 18:38 # 2
outlaw
I NEVER AGAIN TO YOU, OR NEVER GO TO SERVICE UNLESS YOU ARE IN VERY DIFFICULT CONDITION ...
IT IS NOT DIFFICULT TO UNDERSTAND THE LEAK AND ONLY THEY WILL BE HAPPENED FOR THEM ...
CARTELIN IS MISSING THE MOTOR OIL WITH GREAT POSSIBILITIES.
DRIVE THE FINGERED OIL FINGER AND IF YOU CAN GET THE ODOR FRAGRANCE OF ODOR. Wink
08.05.2020 18:38 # 3
rifatseker
Check the engine top cover gasket for crankcase gasket. Visually check the engine, whether the oil comes from the top or the bottom, lift the car from the fiber, and look at it from under it, it can come out of a small thing or be the harbinger of a big problem. It is necessary to care about oil leaks.
08.05.2020 18:38 # 4
madblueblacksea
You can understand the oil cap by washing the healthiest engine. Searching for oil and diesel oil leakage is like looking for a needle in a haystack.
08.05.2020 18:38 # 5
outlaw
[QUOTE = madblueblacksea] You can understand the oil cap by washing the healthiest engine. Searching for oil and diesel oil leakage is like looking for a needle in a haystack. [/ QUOTE]
WHEN I SOLVE OIL LEAK, I DON'T BREAK THE BRAIN, SENSOR AND WATER TO THE BRAIN, I WILL NOT BECOME THE CAR. LOLLOLLOL
08.05.2020 18:38 # 6
madblueblacksea
[QUOTE = outlaw] [QUOTE = madblueblacksea] You can understand the oil cap by washing the healthiest engine. Searching for oil and diesel oil leakage is like looking for a needle in a haystack. [/ QUOTE]
WHEN I SOLVE OIL LEAK, I DON'T BREAK THE BRAIN, SENSOR AND WATER TO THE BRAIN, I WILL NOT SLEEP THE CAR, I AM SAYING ... "LOL"
Don't go off the sidewalk, it was like a flowerpot on your head.
It is not even sincere to think that the oil leaking from the crankcase from the crankcase is because the wind that fills in the hood in the course of the cruise will infect all sides.
08.05.2020 18:38 # 7
pierson
It happens to me too ... After the car stopped, sometimes a few drops, sometimes more ... I asked the master about sweating, he said, "If we have too much, we will see it." always drop of oil always black
08.05.2020 18:38 # 8
Serkan
If it keeps leaking slightly after stopping the engine, it is from the crankcase gasket, the oil is cut after filtering into the crankcase, the crankcase gasket problem is already chronic in the 206's.
08.05.2020 18:38 # 9
medakilec
Yes, after waiting a bit, it seems to be cut. Meanwhile, I check the engine oil both from the dipstick and from the digital display. whether there is a marked decrease in engine oil
08.05.2020 18:38 # 10
medakilec
[QUOTE = pierson] It happens to me too. After the car stopped, sometimes a few drops, sometimes more ... I asked the master about sweating. everywhere cars are parked, always drop of oil always black [/ QUOTE]
08.05.2020 18:38 # 11
muro_60
You can wash the engine beautifully and find out where it is running. Services fly in the air.
08.05.2020 18:38 # 12
medakilec
WHAT HAPPENS DOES IT EXPENS IN THE LEAKAGE CARTER CONTACT?
08.05.2020 18:38 # 13
medakilec
YES YOU NEED TO FIND A SOLID MASTER
08.05.2020 18:38 # 14
muro_60
As far as I know, there is no gasket. Liquid gasket is applied. Fabrication green liquid gaskets are used. If they are used, it will not be a problem.
