car not working problem
08.05.2020 15:47 # 1
goktug
friends, when I get in the car today, I started the starter but it does not work. just like when the petrol runs out. battery and starter do their job but the car does not work. he has difficulty working as if there was no gasoline with the starter pressed. I did not understand that I brought the expert. he said it might be hot. I left it to the authorized service with the tractor. They will look. They said we'll say tomorrow. Do you have any problems?
08.05.2020 15:47 # 2
werty
The gasoline pump may not be pressing the gasoline. The electricity may not be flowing. I had a situation like this. or it may be clogged, there may be a lot of slacks. You can close the car to a lot of money from malfunctions.
respects.
08.05.2020 15:47 # 3
It sounds like an immobilizer.
08.05.2020 15:47 # 4
werty
[QUOTE = koliva] sounds like an immobilizer. [/ QUOTE]
+1
08.05.2020 15:47 # 5
goktug
Hojam, I never thought of it. Could I have changed the contact control case yesterday?
08.05.2020 15:47 # 6
goktug
Will I try to run with a spare key?
08.05.2020 15:47 # 7
[QUOTE = göktuğ] hojam, I never thought of it. Could I have changed the contact control case yesterday?
It is probably from her. If you have a spare key, let's see if it works.
08.05.2020 15:47 # 8
goktug
koliva thanks, my brother never thought of me. If the car is not closed at the service, I'll go right away. but I will ask something. I put the chip in the control box or something, why would he do something like this ...
08.05.2020 15:47 # 9
[QUOTE = göktuğ]
If you want, let's go and try and talk Gülme
08.05.2020 15:47 # 10
goktug
service closed, I called, they did not open, let me go early with a spare contact ...
08.05.2020 15:47 # 11
[QUOTE = göktuğ] service closed, I called, they did not open, let me go with a spare contact early ... [/ QUOTE]
It is observed that the immobilizer does not work even when the battery is replaced. Maybe you have removed the battery or there was a momentary contact.
08.05.2020 15:47 # 12
goktug
Now the release button of the control box was broken and I bought a new control box. I unscrewed myself and put everything back in it, only the screw in the contact part of the controller was old, and I installed another screw. so. I paid utmost attention not to fall through it ...
08.05.2020 15:47 # 13
goktug
As I said, the problem was that I changed the contact control box. car with spare contact. Now, how can we introduce the remote control to the car guys? göktuğ 2011-07-09 12:40:42
08.05.2020 15:47 # 14
1. Turn the Ignition switch to the ON position using the first key.
2. Press the LOCK button for 10 seconds.
3. Remove the key and wait for 10 seconds.
4. Check the Plip key operation.
5. Repeat for second Plip key if required.
6. Turn the ignition OFF
08.05.2020 15:47 # 15
goktug
Koliva brother can you explain more clearly. will we do this by connecting to the computer ...
08.05.2020 15:47 # 16
I do not think. I also changed the key switch because the control switch's on / off button is broken. 30 of us love gayme. but I did not have such a problem. try it anyway. maybe if they broke the chip.
08.05.2020 15:47 # 17
metin
I came to my mind at the meeting of beykoz,
they had changed the control box of deniz206, they did not put the immobilizer chip into the new container, they were pressing the starter it did not work until it did not work until the cecoli abi immobilizer chip did not forget the lights that opened on the face of our ahmets.
I briefly say that I could not read the imobilizer.
08.05.2020 15:47 # 18
[QUOTE = göktuğ] koliva brother can you explain more clearly. will we do this by connecting to the computer ... [/ QUOTE]
Now I looked again, but in my previous message, what I recommend in English is for programming the remote control. So it's not about immobliser. In your case, the 4-digit code belonging to your vehicle needs to be entered on your key. Bringing your most beautiful vehicle to the service and having the control programmed. Keep us informed about developments.
08.05.2020 15:47 # 19
gozem
Apart from the mechanism on the remote, there is a piece that looks like a stone hidden in the corner. Did you switch it to the new remote? otherwise it will not work. I hope you did not throw your old remote .. imbolizer
08.05.2020 15:47 # 20
goktug
No, I haven't seen him. I didn't know it was. the old commander knows where god is. Our command is complete ...
Page : / 2
