Car Not Working Emergency
08.05.2020 17:02 # 1
kerem
Hello everyone.
I turned the ignition to start the car in the morning, but the vehicle did not work. What could be the reason for this?
edit: I had the vehicle fitted lpg peugeot 307 and 9-10 months ago.
kerem 2012-09-12 19:44:28
08.05.2020 17:02 # 2
ozaannn
Gas pump can be ac contact lift back seat but first hear a sound from the tank for 5 seconds
08.05.2020 17:02 # 3
kerem
I just went and videotaped with the camera. Here is the situation: I turn the S switch, the sound is short while working, then the lights etc. turn off by itself, and then it turns on after a while.
kerem 2012-09-12 19:42:59
08.05.2020 17:02 # 4
berk2309
Are you sure that there is no problem in your brain, teacher, do you realize that the airbag is burning in the airbag & nbsp; the passenger airbag & nbsp;
08.05.2020 17:02 # 5
berk2309
how do you hear the sound when you turn the bidet into the ignition? I did not get it.
08.05.2020 17:02 # 6
kerem
I am not sure that it may be unfortunately. I also noticed it but I do not understand much from the car. I spoke to a master at the service, he said he could have a starter engine.
08.05.2020 17:02 # 7
kerem
There is no difference when I tried to operate in LPG or gasoline. So when turning the ignition, the sound is working, but it is very short.
08.05.2020 17:02 # 8
berk2309
If spontaneous lights are going to go off, he's done with a flock.
08.05.2020 17:02 # 9
kerem
I turn the ignition on then the vehicle turns off automatically before the car starts.
Sorry, maybe it might sound funny, but the headlights etc are normal, the radio works?
08.05.2020 17:02 # 10
berk2309
No, why should the neighbor come, my teacher may be in contact with the problem.
08.05.2020 17:02 # 11
kerem
Anyway, I'll take it with the tow truck, we'll see the service after that: S İnş. battery is the easiest to solve.
08.05.2020 17:02 # 12
monur
You should give a charge to the battery and try it, the battery of the car is depleted, probably the starter is dead.
08.05.2020 17:02 # 13
kerem
Ok let me try your friend from the vehicle. I hope
08.05.2020 17:02 # 14
1) The battery is exhausted.
2) There may be a problem with the starter motor. Starter motor automatics and starter charcoal are exhausted.
08.05.2020 17:02 # 15
kerem
Soon we will have friends, we will try to supplement the battery. Thank you very much indeed. Not bad to know.
08.05.2020 17:02 # 16
berk2309
we wait for the result, let's see after the battery charge
08.05.2020 17:02 # 17
Serkan
I think it looks like a battery, the starter motor never turns.
08.05.2020 17:02 # 18
goktug
[QUOTE = laedri]
2) There may be a problem with the starter motor. Starter motor automatics, starter coal are exhausted.
i agree with friend. the problem you described looks like this. If there was a 2nd problem, there should be no sound when turning the ignition. check the battery, I think.
08.05.2020 17:02 # 19
ozaannn
There is nothing more than the acuden and mars dynamo. I think it is harmful to knock the vehicle.
08.05.2020 17:02 # 20
kerem
Yesterday, the friend came, we did not try the charge supplement. Then I asked a master in the morning today, if your cable is thin, he said it might be 99% from the battery. (The cable was thin too).
Also, my batteries are 60 amps? 307- 1.6
kerem 2012-09-13 09:06:37
Page : / 2
