CAR MOVEMENT INDICATOR OPENS 120 FANS
08.05.2020 20:31 # 1
karakartal71
Gentlemen, there was a sudden increase in temperature in my car, so the pole was 120 seconds, the fans turned on, the text came out, "engine heat failure please stop right pull, etc." I was afraid then pulled to the right but the engine was not so hot. Then the first key shows around 70, while the second key, ie, the contact remained at 70 for 5 seconds. it has improved from time to time, it was 90 and so on, and then this breakdown came again 120 fan switching light on, but the engine was not so hot. the same happens even when the engine is cold. overheating fan turns on complete but there is nothing in the engine I'm touching my hand please help thank you in advance
karakartal71 2017-08-17 23:49:28
08.05.2020 20:31 # 2
The problem is probably due to overheating. There is also a decrease in water in the vehicle. but you also have air in the system, check it and never use your vehicle without antifreeze.
08.05.2020 20:31 # 3
aykutbayram1996
Your trouble was the same with the indicator, the fan could last until the end was not even the car was hungry, then I checked the entire cooling system.
08.05.2020 20:31 # 4
karakartal71
what does that mean? not getting chassis?
08.05.2020 20:31 # 5
karakartal71
Whether [QUOTE = sonerkyl] is past, the problem is most likely caused by the temperature sensor. There is also a decrease in water in the vehicle. but you also have air in the system, check it and never use your car without antifreeze. karakartal71 2017-08-18 14:44:55
08.05.2020 20:31 # 6
karakartal71
[QUOTE = aykutbayram1996] Your worry was the same about the indicator, it came to the end, even the fan couldn't even drive the car.
08.05.2020 20:31 # 7
[QUOTE = karakartal71] [QUOTE = sonerkyl] The problem is most likely caused by overheating. There is also a decrease in water in the vehicle. but you also have air in the system, check it and never use your car without antifreeze. [/ QUOTE]
Now, when I look at it, my teacher was sold completely with the thermostat.
08.05.2020 20:31 # 8
karakartal71
Whether [QUOTE = sonerkyl] [QUOTE = karakartal71] [QUOTE = sonerkyl] is past, the problem is most likely due to overheating. There is also a decrease in water in the vehicle. but you also have air in the system, check it and never use your car without antifreeze. [/ QUOTE]
Do you know the service, how can you learn how many changes are complete?
08.05.2020 20:31 # 9
Unfortunately, I do not know the peugeot private service I know, but they are recommending auto from the forums from the forums. They went once.
link for master advice in Ankara
08.05.2020 20:31 # 10
aykutbayram1996
My electric teacher is not connected to the battery, the battery is connected to the battery.
