Car interior camera with rear view camera
08.05.2020 20:45 # 1
necmettinn
First of all hello to everyone.
As I installed on my previous vehicle, I wanted to attach a rear view camera to my Pegueot 407 1.6 HDI Comfort model. When I was at E, I said the monitor should be in the rearview mirror and a camera for pre-registration, and I rolled up the sleeves ... I thought the cable route and the operation steps could be useful for those who want to attach a rear view camera or parking sensor by sharing the steps I have done. The first job was to order from the China site, the material arrived in 15 days. 109TL. no customs, no cargo. The package includes a monitor rearview mirror, rear view camera and cigarette lighter adapter for feeding. It can record on Micro SD card but it is not included in the package.
First of all, I wanted to test it by installing the system on the table to see if it has any problems and to work up to three or five up and down. 12V. I made the connections with the adapter, the rear view camera has a socket connection for the mirror, in addition to the reverse lamp. When the voltage comes through the reversing lamp connection, the guide lines become active. Other times, it can record in the back camera together with the front camera.
First I fastened the mirror with the tires on the original rearview mirror and fixed it. I started laying the cables from this point. Friends who want to attach a parking sensor can attach the monitor's monitor next to the rearview mirror and pull the cable from the same route.
first images ... Although it does not appear clearly in the photo, the image can be seen much more clearly. That's how it came out in the picture because it made a glare from the light. :)
Starting points of cables ...
You can lift the glass side of the ceiling tile slightly under the cables. In this way I came to the edge of the door.
When you pull the side post cover inwards, there is a tab on the top, it comes out. I passed the cables from under this cover to the door rubber.
When you pull the door rubber towards you, it comes out of the bonnet, any nails etc. No, don't be tight. I kept passing both the voltage and the rear view camera cables coming from the mirror under the door rubber. There is enough space under the tire towards the body, it fits easily and there is no problem.
After disconnecting the voltage cable as in the upper picture, I continued to pull the cable of the rear view camera under the front door edge plastic. When you lift this plastic upwards, you need to save it from two nails, but be careful not to break the nails ... After getting rid of the nails, it will be easier if you first save the pole from the plastic cover there and then recover it by the hood opening latch. At this point, only friends who will attach a parking sensor have to continue pulling the cable to the back brain, they will not disconnect any voltage cables ...
Between the two doors, lift the cable slightly below the inner plastic, I've spent ...
Like the front door plastic, I carefully pulled the back door plastic upwards and freed it from its nails. I put the cable under it and put it back in place.
When I tilt the lower part of the back seat forward, the side plastic is almost wasted, maybe I don't know because the nails are missing, but I passed this area easily ...
There is a hinge in the area near the door when the back seat is tilted. From there, you can immediately go under the luggage upholstery.
It is easy now after getting into the trunk ... I removed the cover behind the stop lamp, I connected the feed end of the rear view camera to the yellow cable, if I don't remember the wrong coming to the reverse lamp. (For the parking sensor, a voltage must be received from the reversing lamp to the sensor brain (+), for the brain (-) the chassis end will be taken from the socket here. Also, the monitor tip from the front will be plugged into the corresponding socket of the brain, and after the rear sensors are installed, the four sensor tips are here will enter the brain)
I put the cable of the rear view camera behind the bumper by drilling a hole, plugged it into the socket of the cable I pulled from the front. I screwed the camera between the license plate lamps with two screws.
The front of the camera is almost flush with the bumper ....
There is only one problem, the leds around the rear view camera are whirring when the camera is inactive. doing, it goes out 1.5 minutes after switching off the ignition. The LEDs are normal when the rear view camera is active. I said it goes out 1.5 minutes after the ignition is turned off, but one of them continues to lightly faintly. I guess that the reversing camera also has a recording feature, so I guess that it gets voltage from the mirror, I connected the (+) end resistor from the reversing lamp, nothing changed. I hope it will not cause any trouble ....
I do not know how beneficial sharing has happened or does it work for someone but I wanted to share ... I will continue to share possible changes, glitches, malfunctions and positive situations from this title again ... I would be glad if those who have knowledge or opinions about whirring give ideas ... Good evening everyone ...
08.05.2020 20:45 # 2
talip206
My health teacher was super. How is the recording quality clear enough to read the license plate of the vehicle in front.
08.05.2020 20:45 # 3
necmettinn
[QUOTE = talip206] Your health teacher was super. How is the recording quality clear enough to read the license plate of the vehicle in front. [/ QUOTE]
Thank you teacher. Quality can record in super HD or Full HD. Let me read the plate, you will notice whether the tailgate of the vehicle in front is original or painted: D is so .... I hope I will upload the photo of the image quality again tomorrow ...
08.05.2020 20:45 # 4
OguzhanKucuk61
It is very nice to apply health to your hand. Lecture also use it good bye :) If you share the product link, it would be better.
08.05.2020 20:45 # 5
necmettinn
[QUOTE = OguzhanKucuk61] It's nice to apply health to your hand. Lecture also use it good bye :) If you share the product link, it would be better. [/ QUOTE]
Thank you. I did not specifically give the product link to be perceived as advertising.
This is what I got. But the product range is quite wide. It has disadvantages, it takes a lot of space on the memory card because it saves the video in .mov format. Camera viewing angles are also important, the front is 170 ° and the rear is 140 ° when I get it. Supported memory card capacity 32GB. After all, the friends who are thinking of taking it will benefit their purchasing by looking at their features.
Have a good day.
08.05.2020 20:45 # 6
onlycihan
thank you for sharing. I have a mirror camera inside the mirror in my car.
08.05.2020 20:45 # 7
necmettinn
[QUOTE = onlycihan] thank you for sharing. my car has a mirror inside hidden back parking camera if meret is broken i will buy and use this kind of product but it does not happen :) always other places cause problems [/ QUOTE]
Unfortunately, as you know, it does not come to tamper, everywhere is electronic ... Even a ceiling light bulb can be a problem sometimes ... I made the led lamps on my previous car.
As I mentioned, the only problem for now is the camera lamps, at worst I will cancel the camera lamp ... good luck, let's see ... :)
08.05.2020 20:45 # 8
and
Nice work, use it bye.
08.05.2020 20:45 # 9
necmettinn
[QUOTE = and] Nice work, use bye. [/ QUOTE]
Thanks...
08.05.2020 20:45 # 10
Good health for your hands that have been shared and narrated. I hope you will be satisfied using it
08.05.2020 20:45 # 11
necmettinn
[QUOTE = sonerkyl] Have a nice sharing and expression, good health to your hands. goodbye use [/ QUOTE]
Thank you sonerkyl teacher ... Do you have any idea about the camera LEDs whirring, do you think any damage or can be prevented?
08.05.2020 20:45 # 12
onlycihan
I think there is no harm, just because of the burning of the LEDs, the life of the LEDs may be shortened. 1-2 minutes after the stop is stopped, the vehicle will completely turn off when the vehicle is completely off. It will not be obvious in the day. doesn't matter too
08.05.2020 20:45 # 13
necmettinn
[QUOTE = onlycihan] I think there is no harm, just because of the low burning, the life of the leds may be shortened. 1-2 minutes after the stop is stopped, the vehicle will completely turn off with the electricity cut off. in the environment, it may not be very important [/ QUOTE]
Thank you for the information, teacher ...
08.05.2020 20:45 # 14
necmettinn
Front camera HD image
Rear camera normal position view
Image of the rear view camera showing the vehicle is reversing
I did not get the Full HD of these images, but if I want, I can download and upload them as well.
51 second image in HD format 1 GB. takes up space. I currently have a 1 GB memory card. I was unable to use the registration event fully. 16 GB. We have ordered the memory card as well, let's see that today ... we will fully test the registration event when we arrive ... I hope ... Good evening ...
08.05.2020 20:45 # 15
maximusti
[QUOTE = NECMETT Dunn]
You put good health and craftsmanship in your hands.
If we come to the product, the 51-second image will fit on a 16GB card, 810 seconds, or 13 minutes, in my opinion, a low time. but it is considered good according to the price, just as the front-mounted camera, even crappy products 60 70 TL in Turkey.
08.05.2020 20:45 # 16
necmettinn
[QUOTE = I maximus] [QUOTE = NECMETT Dunn]
Thank you, thank you ... The reason why the time is short is that the front camera saves the separate rear camera separately ... It saves two different folders on the SD card. It makes sense to record both in it ... Using the most beautiful high capacity SD card ... Good day ...
08.05.2020 20:45 # 17
necmettinn
INFORMATION...
I reviewed the recording files ten camera record 800mb. rear camera recording 375mb. Both 51 sec. I sent a message to the seller that there was a way to convert the recording format to mp4 or mpeg format instead of Avı. He wrote that there is no need for such a possibility. He wrote that I should not worry about the circular video recording feature. 16 GB. Let's see what happens when I insert the memory card ....
08.05.2020 20:45 # 18
samet206
If the product does not lose its durability, it looks useful and original as a system, health in your hand. I am telling you because I see some people tend to deliberately damage the property in such cases or they are deciphering because of the camera, or they give up because of the deterrent effect.
samet206 2018-02-02 15:55:30
08.05.2020 20:45 # 19
necmettinn
[QUOTE = samet206] If the product does not lose its durability, it looks useful and original as a system, it will be more functional if it saves you in the park rather than traffic, but memory and charging problem arises for this. Of course, I am telling you because I have seen many benefits, some people tend to deliberately harm the property, in such cases they are deciphering because of the camera, or they give up because of the deterrent effect.
It is written in the description of the product that it has a battery of 450ma / h, it has motion sensor. But I was only able to see the 5sec effect of the internal battery. Either I had to sing before using it, I didn't know it, or I need to go a little long and make it an orient. The motion sensor looks like I said, but I haven't tried it. As you said, the biggest problem is memory event ... If I didn't calculate wrong, max memory of 32gb. It records half an hour. Perhaps it records because it will be sensitive to motion, but if you do not notice it, you can print it with circular recording. Let's see if we can test and see the full features. Have a good day.
08.05.2020 20:45 # 20
keqir
There has been a sharing that will guide the friends who will do this job, health to your labor.
Page : / 2
