Car Dashboard Warning light.
08.05.2020 19:42 # 1
irfan
Does anyone know what this warning light means: S
08.05.2020 19:42 # 2
aktivist
not sure but abs sensor malfunction
08.05.2020 19:42 # 3
Ahmet_ach
It may be esp, but I know that there is no esp in the 206s, this sign may be abs. Does the abs come into play?
08.05.2020 19:42 # 4
irfan
I wonder if the rear suspension is at a 2% burst level, so it might be warning. If the balance is like a new entry in the component, they would report it as malfunctioning if there was a shortage of abs, but it seems to work normally. ? lore 2016-03-10 22:54:42
08.05.2020 19:42 # 5
gergerli
Esp sensor is disabled ... You have to look at the bottom of the wheel, it is connected to the computer and looked at it, my master lowered the left wheel, slept under it, found the sensor, repaired it, the problem was solved 50 TL ...
08.05.2020 19:42 # 6
irfan
I don't have the same problem before, but I don't have esp
08.05.2020 19:42 # 7
gergerli
This esp Warning Light yes I also had 206 xt bva and this light did not end, then I was talking about the situation
08.05.2020 19:42 # 8
irfan
[QUOTE = tense] This esp Warning Light yes I also had 206 xt bva and this light didn't end, then I was talking about [/ QUOTE]
NO ESP In the car there can be no ESP Warning light: /
08.05.2020 19:42 # 9
talip206
There is no esp in 206. That light is abs light. There are signs and meanings in the link.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=8265
08.05.2020 19:42 # 10
irfan
[QUOTE = talip206] There is no esp in 206. That light is abs light. There are signs and meanings in the link.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=8265[/quot A]
Wouldn't ABS be flagged in the connector if it were ABS?
08.05.2020 19:42 # 11
talip206
[QUOTE = irfan] [QUOTE = talip206] There is no esp in 206. That light is abs light. There are signs and meanings in the link.
I am sure it is light abs heat. As for the komputest incident, I don't know it. Maybe it failed later, maybe the socket was loose, maybe it was a serious failure. Sometimes the Peugeot bipper can burn the abs light when the pad is finished. We cannot say anything without being connected to the device.
08.05.2020 19:42 # 12
fætih
abs lamp. has a brain in the front left. If the plug is unplugged and does not correct, check the sensor. abs life-saving hardware.
08.05.2020 19:42 # 13
I also have your brake pads checked.
08.05.2020 19:42 # 14
emresensoy307
There are esp at 206 xt 1.6
08.05.2020 19:42 # 15
irfan
[QUOTE = koliva] I also have your brake pads checked. [/ QUOTE]
There is a hardening in the brake case, it requires a complete maintenance, I think it is necessary to show it before I get more trouble :)
[QUOTE = emresensoy307] There is esp at 206 xt 1.6 [/ QUOTE]
206 XR
[QUOTE = fætih] abs lamp. has a brain in the front left. If the plug is unplugged and does not correct, check the sensor. abs life-saving hardware. [/ QUOTE]
I couldn't get the plug stuck together, let me see it when you take it to the master :)
