Car Care For Your Car Against Rust And Decay
08.05.2020 14:00 # 1
Manufacturer companies generally exclude the corrosion caused by environmental pollution, mud, and atmospheric wastes. The first intervention you can do against rust is to apply the Rust Prevention Systems applied by the vehicle maintenance centers when your vehicle is new. The insulation of the base plate of the vehicle should be checked frequently, if the insulation is swollen, there is a risk of rusting.
Make sure that your vehicle's water discharge holes and ducts are open,
To periodically wash the bottom of your vehicle,
After washing your vehicle, make sure that the sensitive parts such as under the doors, fender interiors, fender edges, trunk grooves, engine compartment, interior of the sill profiles, the inside of the carrier system profile and the door pillars are thoroughly cleaned and dry,
To remove the small bumps and scratches that may lead to rust on the body of your vehicle by touching it up instead of pastry polish, which will make it unprotected against external factors,
Washing your vehicle with a sponge instead of a brush and preventing fine scratches that may occur,
These are measures that will prevent your vehicle from rusting.
08.05.2020 14:00 # 2
sinan-s
thanks for the biligler
08.05.2020 14:00 # 3
yj 9542
Thanks for your sharing.
