can you read this
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 17:04 # 1
gngburak
greet everyone,
& nbsp;
my problem & nbsp;
when I brake fast on a straight road
as if my foot is pedaling and the steering wheel is shaking I wonder.
08.05.2020 17:04 # 2
gngburak
My car is 206 x-line 2005 mod.
08.05.2020 17:04 # 3
muro_60
If the ABS is activated, the pedal will vibrate, normally it will do from the ducts.
08.05.2020 17:04 # 4
gngburak
I understood that the vehicle has no abs, and the disks are changed to 84 thousand.
08.05.2020 17:04 # 5
zgr
the same problem existed in my vehicle. the brake pedal was hitting a truck. discs changed problem solved. but you are just calling the disks. front or back of your vehicle disc?
08.05.2020 17:04 # 6
Serkan
The discs may be damaged if water is caught while hot.
08.05.2020 17:04 # 7
gngburak
no front disk only
08.05.2020 17:04 # 8
gngburak
I guess I was holding it
08.05.2020 17:04 # 9
muro_60
If you want to try and pour water while the discs are hot :)
08.05.2020 17:04 # 10
06OzGuR06
My friend also recommend you to look at the rear drums, because the same situation happened to me. When I applied the brakes while going at high speed, it hit the pedal. I changed the front discs and the problem was not solved. You can understand the handbrake by pressing the button very lightly on an empty asphalt road while traveling at a speed of km.
08.05.2020 17:04 # 11
gngburak
Thank you for your advice. gngburak 2012-10-09 10:08:49
08.05.2020 17:05 # 12
MagicPerformance
Have your brake hoses checked.
08.05.2020 17:05 # 13
gngburak
How much will this cost in the service?
08.05.2020 17:05 # 14
mev347
I paid a full 300 TL on Saturday including front brake hoses, rear complete brake system, pads, brake fluid lining spray and labor
08.05.2020 17:05 # 15
gngburak
did you have the servo in industry?
