can you look from sedre
08.05.2020 16:53 # 1
istanbullu_3886
Hi friends, I have a variable hydraulic power steering on my car, but it does not give speed information to the steering wheel. I think there is an electronical error.
08.05.2020 16:53 # 2
istanbullu_3886
current
08.05.2020 16:53 # 3
Where exactly do you want me to look at?
08.05.2020 16:53 # 4
istanbullu_3886
[QUOTE = koliva] Where exactly do you want me to look at? [/ QUOTE] & nbsp; good morning how are you & nbsp; & nbsp; power steering brain inlet multi-socket connection diagram
08.05.2020 16:53 # 5
[QUOTE = istanbullu_3886] good morning how are you & nbsp; & nbsp; power steering brain inlet multi-socket connection diagram [/ QUOTE]
Steering pump diagram below. I guess this is not the sema you are looking for
08.05.2020 16:53 # 6
istanbullu_3886
[QUOTE = koliva] [QUOTE = istanbullu_3886] good morning how are you & nbsp; & nbsp; power steering brain inlet multi-socket connection diagram [/ QUOTE]
Steering pump diagram below. I guess this is not the sema you are looking for.
[/ QUOTE] tsk edrim koliva brother, the cables in the dissection pump need me to go where we can get into these phrases.
08.05.2020 16:53 # 7
istanbullu_3886
I can write if the serial number is required, my brother
08.05.2020 16:53 # 8
[QUOTE = istanbullu_3886] thank you koliva brother can i go into these phrases if there is no need to go where the cables in the dissection pump go? From the left it enters BSI's number 12 leg.
08.05.2020 16:53 # 9
istanbullu_3886
very & nbsp; thank you bro
08.05.2020 16:53 # 10
[QUOTE = istanbullu_3886] too & nbsp; thank you bro [/ QUOTE]
You are welcome "Wink"
08.05.2020 16:53 # 11
istanbullu_3886
We looked at the vehicle yesterday on the scheme, while the socket was changed, we saw that the solder and the macron were not used, we saw that the oxide was oxidized. After the process was completed, the dissection pump did not work, and if the term of the dissection was unsatisfactory, it was like a pile and again we added the cables with the number 9 and number 5. We didn't leave much for we will look at our available time again
08.05.2020 16:53 # 12
You're talking about cables 5 and 9 on the pump, right? I said there are 9 different places, so let me ask.
08.05.2020 16:53 # 13
istanbullu_3886
yes brother I'm talking about the cables on the pump
08.05.2020 16:53 # 14
Serkan
You can handle it too, I saw the determination in your brother, by the way, tomorrow I will be able to get my usb input device called audio system tomorrow, if I need to activate it from pp2000, I can come next to you abi & nbsp; "Smile" Serco05 2012-07-08 10:52:36
08.05.2020 16:53 # 15
[QUOTE = istanbullu_3886] yes brother I'm talking about the cables on the pump [/ QUOTE]
Leg number 5 comes from the fuse number F3 from the fuse panel. The number 9 leg comes from BSI. I don't understand why together. You're sure you're looking at the right legs, aren't you?
08.05.2020 16:53 # 16
istanbullu_3886
[QUOTE = koliva] [QUOTE = istanbullu_3886] yes bro, I'm talking about the cables on the pump [/ QUOTE]
It comes from the fuse numbered F3 from the leg number 5 fuse panel. The number 9 leg comes from BSI. I don't understand why together. You're sure you're looking at the right legs, aren't you?
[/ QUOTE] I think he's using electricity from the f3 fuse.
08.05.2020 16:53 # 17
[/ QUOTE] I think he's using electricity from f3 fuse. It is already. Reviews
08.05.2020 16:53 # 18
istanbullu_3886
[QUOTE = Serco05] You can handle it too, I saw the perseverance of my brother, I will be able to get the usb input device called audio system to my car tomorrow. border = "0" alt = "Smile" title = "Smile" /> [/ QUOTE] as long as there is such assistance in this form, we will not be able to deal with it, brother, I got the audo system, I did not need it because it was 5 cd cd but it did not fit the first tactics. the tactics they had worked as drekt may not need to be activated or may be incompatible when you take note I think
08.05.2020 16:53 # 19
Serkan
[QUOTE = istanbullu_3886] [QUOTE = Serco05] If you take care of it, I saw the perseverance of you, I will be able to get the usb input device called audio system tomorrow, if I need to activate it from pp2000, I can come next to it if you need to activate it from pp2000 abi & nbsp; [/ QUOTE] in this form, as long as there is so much help, we will not be able to deal with it, brother, I got the audo system, I need 5 li CDs so it is not necessary. but the first tactics did not match, the second tactics worked as drekt, it may not be necessary to activate it or it may be incompatible when you get it, I think it will be inconsistent
Okay, I will take notice of the warning, I have not decided in the cut. src = "smileys / smiley1.gif" border = "0" alt = "Smile" title = "Smile" />
08.05.2020 16:53 # 20
istanbullu_3886
the original product is always good but i am not happy with that wave when i press the horn it makes a sizzling music is not very clear i think i will buy a nice tape
Page : / 2
