Can you help with my 406 problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 20:44 # 1
Taktak55
In our 406 vehicle we bought a Yen, we encountered the problem of idling, injected the vehicle, but when we got the flat lpg installed, the topic stops when we start the vehicle first, but it does not stop before seeing 3000 cycles, but when it goes to the 3000deg the tube, it does not stop, how many masters went to the butterfly throat or upper cap will open. They said our mood was broken. I went to my repair shop, told me to get the top cover off, I told him to take a look at the vehicle, I just took a look at the car, the room was canceled all the parts of the tube. We re-connected the vehicle, started the vehicle, canceling without seeing 3000 cycles, then running it again and stopping at the lpg 3000 cycles, it does not stop because there is less trouble, there is no problem. He said that he was doing this problem in the city, he went to the electrician and checked. He said more, let's make myself what my repairman said, first of all, it is not clear what is going to come out on the cover or something. Taktak55 2018-01-25 11:48:31
08.05.2020 20:44 # 2
GokhaN
I think you have a injector problem
08.05.2020 20:44 # 3
peugeot murat
First of all, what type of engine is there in the vehicle?
08.05.2020 20:44 # 4
Lsuersoy
[QUOTE = peugeot murat] First of all, what type of engine does the vehicle have when it connects to the device?
Hello, I was interested in the subject.
By the way, I have a question, what does the "Wealth Regulation" mean? What does it mean?
08.05.2020 20:44 # 5
[QUOTE = Lsuersoy] [QUOTE = peugeot murat] First of all, what type of engine does the vehicle have when it connects to the device?
Actually, the teacher wanted to say a rich-poor mixture in the regulation of wealth. In other words, when there is no mixture of air and fuel ratio, the vehicle gives engine malfunction light. Causes of throttle-air filter-fuel injectors-map sensor-oxygen sensor (lamda sensor)
08.05.2020 20:44 # 6
KILIC
Hodja, when I say flat LPG in your vehicle, I couldn't understand that part. When you first run it you say that it works on gasoline, the lpg order system. How many models are your vehicle
08.05.2020 20:44 # 7
peugeot murat
REGULATORY REGULATION MEANS LAST CONTROL OF THE ENGINE EFFICIENCY OF THE VEHICLE MEANS EXERCISE OXYGEN PHASE OR FUEL PREPARATION IN THE EXHAUSTED GASES AFTER OXYGEN
