Can you help me set up this system?
08.05.2020 14:52 # 1
wldnsxc
I want to learn how I want to install the system myself in the picture below. How to connect 2 ovals and woofers. Thanks
08.05.2020 14:52 # 2
HakanGokdemir
It enters into the field of Our Hadi, it will help you as soon as you see it.
08.05.2020 14:52 # 3
H-a-d-i
[QUOTE = HakanGokdemir] Going into the field of Our Hadi, it will help you as soon as you see it. [/ QUOTE]
I'm taking it right away, Hakan brother ...
our tape 3250 model. There are 4 RCA outputs as far as I know. It is easy to explain since there are 4 RCA (LOW INPUT) inputs in the amphitheater.
1.oval speaker will be connected to the FL output of the amplifier.
2.oval speaker will be connected to the FR output of the amplifier.
*** It is simple to connect since it is already in the form of FL and FR (+) and (-). one end of the speaker will be positive and the other end will be minus.
One end of the woofer will be connected to the end of the RL (+) and the other end of the woofer will be connected to the (-) end of the RR. therefore RL (-) and RR (+) outputs will remain idle.
so the speakers are the normal connection, the woofer is the bridged connection.
NOTE: I am waiting for your questions if there is somewhere not understood.
08.05.2020 14:52 # 4
I did not understand.
08.05.2020 14:52 # 5
H-a-d-i
Until Emrah tells you again, I will attach it to your vehicle myself, it will be easier for me. You come to the cap materials ...
08.05.2020 14:52 # 6
well bro you know, let's pass brother
08.05.2020 14:52 # 7
MirakGTI
don't over-bridging efficiency
08.05.2020 14:52 # 8
wldnsxc
tape piooner deh 1200 red and white rca output only come on. Meanwhile, I made side door coatings from tşklerfiberglass, it was very nice, I will add it to the site as soon as possible
08.05.2020 14:52 # 9
H-a-d-i
Can you add pictures of the back of this tape (where the RCA is)?
08.05.2020 14:52 # 10
wldnsxc
the tape has only one rca output. So how do I connect the jvc s to the tape? right front 2 left front two
08.05.2020 14:52 # 11
wldnsxc
I gotta take your picture, brother. Of course, the rear right rear left speakers can be canceled, so can I connect them to the other jvc on the front right and front left.
08.05.2020 14:52 # 12
H-a-d-i
[QUOTE = wldnsxc] tape has only one rca output. So how do I connect my brother jvc to tape? Right front 2 left front two? [/ QUOTE]
I think cancel the back doors. Connect the speakers with one end to each (+) and (-) in the picture.
08.05.2020 14:52 # 13
deniz_206
bravo, bro with you 2.0 motor Embarrassed
08.05.2020 14:52 # 14
wldnsxc
the back of the tape.
wldnsxc 2010-08-28 20:19:49
08.05.2020 14:52 # 15
wldnsxc
I added the picture but you still haven't answered
08.05.2020 14:52 # 16
Muhammet CAKIR
the cable that provides the control of the amp system is blue, it is the only blue-colored cable coming out of the jack. this is what you ask if i dont understand wrong when i read :)
